Liouville equation - equilibrium
  • Thread starter Thread starter lakmus
    Equilibrium
The Liouville equation states that in a Hamiltonian system, the volume of phase space and probability density are conserved over time. However, an isolated Hamiltonian system does not reach an equilibrium state, as it remains accessible to various microstates on the energy hypersurface. Equilibrium, a thermodynamic concept, implies a time-independent probability distribution function that is not achievable under the constraints of the Liouville equation. For a system to reach equilibrium, it must interact with an external thermal reservoir, which alters the dynamics and allows the probability density to evolve toward an equilibrium value. Thus, the equilibrium state is not a property of the system itself but rather of the probability distribution function influenced by external interactions.
lakmus
Hi!
I have problem with uderstanding of Liouville equation. Which sais that if we have a
Hamiltonian system (energy is conserved), then the the volume of phase space is
conserved, or equivalently the probability density is conserved (the total derivative
of probability density per time is 0).
On the other hand, and isolated hamiltonian system is going to an equilibrium state,
where the probability density is the same for all state in phase space.
How can system reach the equilibrium, when the probaility density is on the develpment
trajectory conserved and at the beginning is not the same for all state?
Thaks a lot!
... isolated hamiltonian system is going to an equilibrium state,
Isolated Hamiltonian system cannot be "going to an equilibrium state".
Let the energy of such system be ##E##.
In general almost any microstate on the energy hypersurface ##E## remains accessible to the system, it is only a question of time when the system will get there.
This can be easily seen from the Liouville equation: the probability behaves as incompressible liquid, it does not accumulate in some hypothetical microstate of equilibrium (nor in a region of equilibrium) in phase space.
The concept of "equilibrium state" is a notion from thermodynamics, used to describe a body whose macroscopic description - macrostate ##S##(pressure, temperature) has a meaning and whose time variation can be neglected.
In statistical physics, knowledge of the macrostate implies probability distribution function ##\rho(q,p)## on the phase space. Since the macrostate of the body in equilibrium can be considered as time-independent, it is most natural to require that the value of ##\rho## for any microstate ##q,p## be also time-independent.
From this assumption and the Liouville theorem it follows that the Poisson bracket of ##\rho## and ##H## vanishes. This can happen if ##\rho## is a function of ##H##.
Th equilibrium value of the distribution ##\rho## is the same only for the microstates that correspond to the energy ##E##, i.e. for ##q,p## such that ##H(q,p) = E##.
It is not the system what can reach the equilibrium. It is the function ##\rho(q,p)## that may reach the equilibrium value ##\rho(q,p) = \rho_0(E)##. In order to accomplish this, however, it has to evolve differently than according to the above Liouville equation, since as you have noticed, the latter preserves the initial values of density ##\rho## (it only changes ##q,p## they correspond to.)
The system has to be brought to interaction with other system (thermal reservoir) and then disconnected. During the interaction, the above Liouville equation for ##\rho## does not apply; there will be new forces due to the reservoir. As a result of these external forces, the resulting ##\rho## may get close to equilibrium value ##\rho_0(E')## for the newly acquired value of energy ##E'##.
Was the above helpful? Now that I'm reading the posts again, I am not sure whether we understood each other.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
