Quick check as to space-like and time-like
  • Thread starter Thread starter nomadreid
nomadreid
I keep getting the terms confused:
1) if I have the equation
-Δr2+c2Δt2=s2
does one say that I am using the (-,-,-,+) signature?
2) Given the above , if s2 > 0 then the interval is space-like, and if s2 < 0 it is time-like, or is it vice-versa?
3) If I now use the proper time τ , is it the same (as far as signature, space-like and time-like) for -Δr2+Δτ2=R2?
4) If R is the space-time radius of an arc in the above, what would that arc be?
Thanks for any help.
hi nomadreid! :smile:
don't worry … so do i ! :rolleyes:
(000,t1) and (000,t2) have time-like separation: two events at the same position but separated in time
(000,t) and (x00,t) have space-like separation: two events at the same time but separated in space
-Δr2+c2Δt2=s2
yes
s2 > 0 means it's mostly a difference in t, so that's time-like :wink:
not following you :confused:
Likes 1 person
-Δr2+c2Δt2=s2
Assuming that by ##\Delta r^2## you mean ##\Delta x^2 + \Delta y^2 + \Delta z^2##, then yes, although it's more customary to list the timelike component first, so that the signature would be (+,-,-,-).
(Note: coordinate differentials are usually written with a ##d##, like this: ##ds^2 = c^2 dt^2 - dx^2 - dy^2 - dz^2##. Note that I put the timelike component first.)
Vice versa. You have one plus and three minuses in the coordinate differentials, so positive ##dt^2## must be a timelike interval; since ##ds^2## has the same sign as ##dt^2##, a positive ##ds^2## must also be a timelike interval.
What you'e written here isn't a spacetime interval; in fact I'm not sure what it's supposed to mean, physically. If you're writing the spacetime interval in terms of the metric, you use coordinate differentials, as above. If you write the interval along a particle's worldline in terms of its proper time, the interval is just ##\Delta \tau##; that's the definition of proper time. If you're trying to write other intervals using the proper time, you would have to set up coordinates such that the particle's proper time was the time coordinate; but in those coordinates the metric probably wouldn't look as simple.
Likes 1 person
Many thanks, tiny-time and PeterDonis. This was a huge help. As far as my last two questions, it turns out that you are both right, that those questions didn't make sense: I had come across the equation using tau in a context of Minkowski space, and automatically stupidly assumed that the author was referring to proper time, which is what tau usually means in this context. However, going over the paper again, I noticed tucked away in a paragraph that the author defined tau as ct. OK, my fault for not noticing this. So questions (3) and (4) were, as you both pointed out, senseless. But your answers to questions (1) and (2) were supremely helpful. Thanks again!
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
