Fortran [Fortran 90] Output is NaN in variables
  • Thread starter Thread starter s_hy
    Output Variables
The discussion centers around troubleshooting NaN (Not a Number) values in variables ep, ht, and hr within a Fortran code for very low frequency (VLF) propagation in the earth-ionosphere waveguide. The user has already checked for common causes of NaN, such as division by zero, undefined variables, and double precision issues, but has not resolved the problem. Key insights reveal that the initialization of the array r leads to zero values for certain elements, specifically r(k) and r(k+1). This results in a division by zero when calculating expressions in the update equations, particularly when j equals k, where 1/r(j) becomes 1.0/0.0, leading to NaN due to the multiplication of infinity by zero. The solution involves ensuring that the array r is correctly initialized to avoid these zero values during calculations.
s_hy
Hi all,
For this problem, I have checked all possible factor that may cause NaN in variables such as
- division by zero --> not found
- undefined variables - set initialization for variables - ep, hr,ht
- parameter setting --> double precision problems checked, no issue
but still couldn't find the cause of the NaN in variable ep, ht and hr as well. need an advice from professionals ( i am an amateur anyway)
Code:
!this is code from berenger 2002 for vlf propagation in earth-ionosphere waveguide.
!equations 7a-7c
!to date, ionosphere is assumed as free space -29/10/2013
subroutine spherical
implicit none
integer                                              :: N, L, i, j, t, k
integer                                              :: ir !, rr
double precision                                :: c, f, lamda, dx, dt, sigma, eps0,u0
double precision                                :: epsr,sigmar,omegap
double precision                                :: dr, dth,rmh,rph
double precision,dimension(300,300)   :: ep, ht, hr, ga, gb
double precision,dimension(300)         :: r
double precision, parameter               :: pi = 3.14159265d0
character(len=20)                              :: filename
!parameter
 k = 201
 L = 100
 f = 3.e9
 u0 = 4*pi*1e-7
 eps0 = 8.8e-12
 c = 1D0/sqrt(u0*eps0)
 lamda = c/f
! print *,'c=',c
 dx = lamda/20
 dt = dx / (2*c)
 dr = 0.05*lamda
 dth = 1*pi/180          !theta  = pi
 !initialize r
 do j = 1,k+1
   r(j) = 0.0
   !print *, 'j=',j,'r(j)=',r(j)
 end do
!do r = 1,dr*(k-1),dr
 do ir = 1, (k-1)
    r(ir) = (ir - 1)*dr
 end do !IR
 !material parameter , assumed to be free space
  epsr = 1d0
  sigma = 1d0
  sigmar = 1d0
!initialization for updated equations
 do i = 1,k+1
  do j =1 ,k+1
    ep(i,j) = 0
    ht(i,j) = 0
    hr(i,j) = 0
  end do
 end do
!material properties
do i = 1, k
    do j = 1,k
        ga(i,j) = exp(-(sigmar*dt)/(eps0*epsr))
        gb(i,j) = (1-exp(-(sigmar*dt)/(eps0*epsr)))/sigmar
        !print *,'ga(i,j)=',ga(i,j),'gb(i,j)=',gb(i,j)
    end do
end do
 ! update equations
 do t=1,L
      write (filename, "('data',I3.3,'.dat')") t
      open (unit=130,file=filename)
      ! source
      ep(1,1) = sin(2*pi*f*t*dt)
      !print *, 'ep(1,1)=',ep(1,1)
    !  update Ez field
    do i = 2,k
     do j = 2,k
       rph = r(j)+dr/2
       rmh = r(j)-dr/2
       ep(i,j) = ga(i,j)*ep(i,j) + gb(i,j) * (((1/r(j)*dth)*(hr(i,j) - hr(i-1,j)) - (1/r(j)*dr)*(rph*ht(i,j) + rmh*ht(i,j-1))))
       !print*, 'i=',i,'j=',j,'r(j) = ',r(j)
       write (130,*) i,j,ep(i,j)
       if (j == 200) write (130,*) ' '
     end do
    end do
     !update Ht (theta) field =Hx
     do  i = 1,k-1
      do j = 1,k-1
         rph = r(j)+dr
         rmh = r(j)
         ht(i,j) = ht(i,j) - (dt/u0/r(j)/dr)*(rph*ep(i,j+1) - rmh*ep(i,j))
         hr(i,j) = hr(i,j) + (dt/u0/r(j)/dth/sin(dth))*(sin(dth)*ep(i+1,j) - sin(dth)*ep(i,j))
         print*,'i=',i,'j=',j,'hr(i,j)  =',hr(i,j)
       end do
      end do
    close (unit=130)
 end do
end subroutine
Technology news on Phys.org
You are dividing by zero (infinity) and then multiplying by zero, which results in NaN.
Code:
!initialize r
 do j = 1,k+1
   r(j) = 0.0
 end do
 do ir = 1, (k-1)
    r(ir) = (ir - 1)*dr
 end do !IR
The first loop sets the first k+1 elements of r to zero. The second loop sets the first k-1 elements of r to (ir-1)*dr. Elements k and k+1? They're still zero. (Aside: r(1) is also zero.)
Code:
    !  update Ez field
    do i = 2,k
     do j = 2,k
       rph = r(j)+dr/2
       rmh = r(j)-dr/2
     end do
    end do
When j=k that 1/r(j) is 1.0/0.0., or +infinity. On the first pass, hr(i,j) - hr(i-1,j) is 0, and infinity*0 is NaN.
Likes 1 person
solved! thank you
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
10K
