Proving the divergence of a Harmonic Series
mtayab1994
Prove that Hn converges given that:
H_{n}=1+\frac{1}{2}+\frac{1}{3}+...+\frac{1}{n}
First I supposed that the series converges to H:
H_{n}=1+\frac{1}{2}+\frac{1}{3}+...+\frac{1}{n}\geq1+\frac{1}{2}+\frac{1}{4}+\frac{1}{4}+\frac{1}{6}+\frac{1}{6}+\frac{1}{8}+\frac{1}{8}+...+\frac{1}{n}
Which implies that H_{n}=1+\frac{1}{2}+\frac{1}{3}+...+\frac{1}{n}\geq1+H_{n}
Which contradicts with the series converging. Hence the series doesn't converge. I know there is another proof where you set H to be greater than an infinite sum of 1/2's but I wanted to think of something else. Is this correct? Any help would be appreciated.
On the track; not quite right.
To prove something diverges -- which this does -- you need to show that it gets greater than any arbitrary integer N . There are various proofs of the divergence of the harmonic series, but the most common one begins like this:
1 +1/2 + (1/3 + 1/4) + (1/5 + 1/6 + 1/7 + 1/8) + (1/9 + ... 1/16 ) + ...
If you can show that the bracketed terms are all larger than 1/2, then you are adding up infintiely many 1/2's. So you can always get larger than any N.
Yes that's the proof I'm talking about because the first bracketed terms are greater than 1/4+1/4=1/2
and the next 4 terms are greater than 1/8+1/8+1/8+1/8 and so on and so forth and at the end you have a sum that's greater than an infinite sum of 1/2. That's it but I was trying to see if the proof I made up was on the right path.
Let's look at an example: ##H_6## = 1 + 1/2 + 1/3 + 1/4 + 1/5 + 1/6 > 1 + 1/2 + 1/4 + 1/4 + 1/6 + 1/6 = 1 + 1/2 + 1/2 + 1/3 = 1/2 + ##H_3##. And checking one step further we can see that ##H_8## > 1/2 + ##H_4##. This is not what you wrote for the general case.
In general then you have ##H_n## > 1/2 + ##H_m## where m = n/2 if m is even and m = (n-1)/2 if n is odd, i.e. m = ##\lfloor{n/2}\rfloor##
In and of itself this is not a proof. You can extend it into a proof by setting up a recursion:
##H_n## > 1/2 + ##H_{\lfloor{n/2}\rfloor}## > 1/2 + 1/2 + ##H_{\lfloor{n/2}\rfloor/2}## , etc. Perhaps you would like to write up this approach.
You came up with a good idea, and that shows me you are interested in mathematics and able to be creative about it.
Or how about if I restate the given information and say prove that the harmonic series:
1+1/2+1/3+1/4+... diverges.
Then now i can suppose that the harmonic series converges to H and we let:
H=1+ 1/2+ 1/3+ 1/4+ 1/5+ 1/6+ 1/7+ 1/8+...≥1+ 1/2+ 1/4+ 1/4+ 1/6+ 1/6+ 1/8+ 1/8+...
which equals 1+1/2+1/2+1/3+1/4+... = 1/2+H .
And the inequality holds because 1/3+ 1/4≥ 1/4+ 1/4 and 1/5 + 1/6 ≥1/6+1/6 and so on and so forth.
So we supposed that the harmonic series converges to H yet we found that H≥1/2 + H , which is a contradiction so therefore the series diverges. I think this is set up much better.
Actually, you don't need a contradiction. You are looking at ##H_n##. Whether there is an H or not you can show ##H_n## > 1/2 + ##H_{n1}## > 1/2 + 1/2 + ##H_{n2}## > ... where each nk is more or less half the preceding one.
If you want to show ##H_n## gets greater than some integer M, you just have to pick n big enough to generate 2M 1/2's. I think that's probably n = 2##^{2M}##.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
