Shuffling cards (a list of integers)
The discussion focuses on the algorithm for shuffling an array of distinct integers to ensure each permutation is equally likely. The proposed method involves sequentially swapping each element with a random element that has not appeared earlier, which guarantees uniform probability distribution. An alternative approach using random permutations of indexes is also mentioned, but it is argued that this method does not achieve the same sequential probability distribution. The necessity of the "does not appear earlier" condition is explained through probability analysis, demonstrating that it ensures each element has an equal chance of being in any position. Overall, the correct algorithm maintains fairness in shuffling by adhering to specific probabilistic principles.
divB
Hi,
I found this problem along with the solution:
"Given
an
array
of
distinct
 integers,
 give
an
algorithm
 to
randomly
reorder
the integers
 so
that
each
 possible
reordering
is
equally
likely.
In
other
words,
given
a deck
 of
cards,
 how
 can
you
 shuffle
them
such
that
 any
 permutation
of
 cards is equally
likely?
Good
answer:
Go
through
the
elements
in
order,
 swapping
each
 element
with
 a random
 element
in
 the
 array
that
does
 not
 appear
earlier
than
the
element.
This takes
 O(n)
 time.
Note
 that
 there
 are
several
 possible
solutions
 to
this
 problem,
 as
well
 as
several good‐looking
 answers
 that
 are
incorrect.
 For
example,
 a
 slight
 modification
to
the
above
 algorithm
where by
 one
switches
 each
 element
 with
 any
 element
 in
the
array
does
 not
 give
each
 reordering
 with
equally
 probability."
I don't understand why this extra step "does not appear earlier" should be required?
I would have created a random permutation of the indexes, and re-ordered the array according these indexes. E.g., from MATLAB:
Code:
% "array" contains my list of distinct integers
shuffle_indexes = randperm(length(array));
shuffled_array = array(shuffle_indexes);
I don't see why this should be biased in any way when the random permutation is completely random.
Thanks
Technology news on Phys.org
Your Matlab code is not the same as the "good" algorithm you were given, because it conceptually does al the swaps "at once" not sequentially. I think the Matlab algorithm does solve the problem correctly - so long as the randperm function is implemented properly.
To see why "does not appear earlier" is required, work through the probabilities of the numbers being where they are, after each step.
After step 1, the first element has probability 1/n of having whatever value it has, and elements 2...n all have probability (n-1)/n.
After step 2, the second element has probability (n-1)/n x (1/(n-1) = 1/n of having whatever value it has, and elements 3...n have probability (n-1)/n x (n-2)(n-1) = (n-2)/n.
After (n-1) steps that gives what you want. Analyzing the version without "does not appear earlier" will show you why it is different.
A different way to see it is that the algorithm you were given is the same as:
"Put all the numbers into a bag. Pick one from the bag at random and put it in position 1 in the array. Pick another number from the numbers left in the bag and put in in position 2. Repeat till done."
Or, if you don't like probabilities, just work through the algorithms on a list of length 3, and see what happens. There are 6 possible orders. The "does not appear earlier" version has exactly one way to produce each of them. Without "does not appear earlier", there are different numbers of ways to end up with different orders.
Likes 1 person
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
