Does using the em field generated by flowing elctricity cause V drop?
Using the electromagnetic field generated by electricity flowing through a wire or coil to push a magnet can affect power flow, leading to voltage drops if significant power is consumed. The concept aligns with linear motors, which utilize changing electromagnetic fields to create motion, similar to maglev trains. While linear motors may offer advantages in terms of reduced friction and drag compared to traditional motors, efficiency comparisons depend on specific designs and applications. Proper coupling is crucial for maximizing efficiency in both linear and rotational motors. Ultimately, understanding the relationship between force, power, and efficiency is essential for evaluating these systems.
Badazbuilder
I was wondering if you were to use the em field caused by electricity flowing through a wire or coil to push a magnetic or object would you effect the flow of power in the line. Like if you were to wrap a one phase of transmission lines around a solenoid type device to use the em field to push a magnet, would you experience power lose, voltage drop or ? in the electrical flow through the line? Also i am licensed electrician but not a college educated electrical engineer, so my terminology may not be 100% on, but I believe this all falls in the realm of inductance. I was basically pondering whether it could be possible to use the power flowing in high voltage transmission lines to power a "charged train" through a tube powered by using the em fields from wrapping these power lines around a "tube" to cause a magnetic push through the tube. Similar to solenoid but on a much grander scale. I get many interesting ideas like this well doing the more mundane aspects of my job and figured it couldn't hurt to ask the pros, but please remember that i am not a engineer so complex formulas may answer the question but help me understand. thanks all happy holidays
Yes it could be done , but power doesn't come from nowhere , yes the current flow would be affected and given sufficient power consumption voltage would decrease too.
Basically , If I get ti right what your thinking , it sounds like a linear motor , look up linear electromotors or linear motors, the maglev train works kinda similar , these devices use the changing em field created by current running through coils to push a physical object in one way or the other.
Likes 1 person
yes, after looking into linear motors it seems to be similar to my line of thinking. i was also wondering whether the power consumption to force ratio in linear motors is any better than a traditional electric motor. if you were to say run a chain through the field to create a chain driven system would you get a better ratio from power used to force created. I know there is very little power used when stepping voltage up or down voltage through a transformer and which basically works off inductance through generated em fields. i know you are not creating a force in a transformer and its different ball game but wouldn't you experience less resistance from wind drag and friction in a linear push then in a traditional rotational electric motor. And again thanks crazymechanic. you pointed me in the right direction. if i have time maybe ill post a sketch to help explain my line of thinking.
well , if you think about any physical air drag or other factors then I think a properly made both linear and typical electric motor has almoust no loses of that kind , ofcourse if you don't attach a giant propeller to it.
About the force, every wire , especialy the one which is part of a coil would it be a motor or transformer or an electromagnet experiences force , the force comes from the magnetic field which is created by the current that passes through the wire/coil.
If you look closely youll see that in both electric motors and transformers the coils are not only laminated but in good devices they are also filled with a sticky and rather strong kind of chemical , paraffin in older models , which is there to prevent coil shaking or ringing or any other physical oscillation that may arise due to magnetic field forces.
No way to use the field caused by current in a line to do work without "V drop". If you couple to the field, you remove energy from the primary wire when you use it to do work.
The best physical system is that which provides the best coupling. A linear motor gives you linear motion without gearing and rotational to linear translation. The problem is getting efficient coupling, which is easily achieved in a self contained rotational motor.
etc.
It is not valid to try to compare or relate Force and Power in different circumstances. The two are not really related, unless you also consider the movement and speed involved.
What you probably want is figures for Efficiency of the various types of motor.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
