Can Earth's Magnetic Field Be Amplified for Levitation Purposes?
The discussion centers on the feasibility of amplifying Earth's magnetic field for levitation purposes. It explores whether an opposing magnetic field can be created to lift objects and if a device could amplify the natural magnetic field to achieve this. The conversation also questions the weight dynamics between the ground amplification device and the levitating upper device, specifically whether the ground device would bear the full weight of the upper device. A reference to laboratory simulations of the Earth's magnetic field suggests that while amplification may be theoretically possible through specific mechanisms, it differs from simply enhancing the Earth's magnetic field. Overall, the concept of using magnetic fields for levitation remains largely theoretical and complex.
Kenbigdeal
If it is possible to calculate the Earth's magnetic field at a given point (ranging between 0.25 to 0.65 Gauss), can an opposing field be created to lift an object? If the natural magnetic field is not strong enough, can it be amplified to the required level? My question is leading to whether a device could be created to amplify the natural magnetic field and a second device could be created to levitate above it carrying any given weight. The ground device would increase the amplification dependent upon the force requirements of the upper device's weight load. This leads to my second question, if the above is possible, would the ground device "feel" the full weight of the upper device? For example, if the ground amplification device weighs 10 lbs and the weight on the upper device is 100 lbs, would a person pushing the devices in unison require the force to push 10 lbs or 100? Thank you for your help in my hypothetical quest.
Kenbigdeal, Welcome to Physics Forums!
Can you think of any mechanism to “amplify” the earth’s magnetic field? I cannot. Here is a paper about simulating the earth’s magnetic field (the geodynamo) in the laboratory, and it does mention “...spiral motion in well-conducting fluids, like liquid metals, can amplify seed magnetic fields to generate dynamo action.” Be careful to not confuse that process with “amplifying the earth’s magnetic field”. which seems you have done.
Naturwissenschaften. 2000 Sep;87(9):381-90.
Can the Earth's magnetic field be simulated in the laboratory?
Müller U, Stieglitz R.
Forschungszentrum Karlsruhe, Institute for Nuclear and Energy Technologies (IKET), Germany.
Abstract
Today it is generally accepted that the Earth's magnetic field, as well as that of many other planets, is generated by buoyancy driven convection in the electrically conducting liquid cores of these rotating celestial bodies. The conversion of mechanical energy into electromagnetic energy is known as the dynamo effect. In contrast to technical dynamos, which utilize the rotational motion of a complex arrangement of wire coils and other materials of different electrical and magnetic properties, the geodynamo is based on a freely developing spiral flow in a practically homogeneous, electrically conducting liquid core domain, and is therefore termed a homogeneous dynamo. This report outlines some fundamental properties of the Earth's magnetic field. The structure of the spiral flow in the liquid interior of planets is explained with the help of some model experiments in rapidly rotating spherical shells, which were carried out by Busse and Carrigan (1974). Based on the main ideas of electromagnetism it is shown that spiral motion in well-conducting fluids, like liquid metals, can amplify seed magnetic fields to generate dynamo action. Starting from the conjectured flow structure in the Earth's interior, a conceptional and engineering design is described for a laboratory dynamo experiment. Some details of the construction of the test facility and first experimental results are presented and discussed.
http://www.ncbi.nlm.nih.gov/pubmed/11091960
It may be of interest that a commercially available Hall-effect sensor that can measure the earth’s magnetic field exist, and connect directly to your laptop, etc.
Magnetic Field Sensor
http://www2.vernier.com/booklets/mg.pdf
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
