Surveying Problem Relating To Circles & Lines
  • Thread starter Thread starter tomtomtom1
    Circles Lines
The discussion revolves around a surveying problem involving a circle and points in a Cartesian coordinate system. A circle centered at point B with known coordinates and radius intersects a line connecting point A, which lies outside the circle, to point B. The goal is to determine the coordinates of point C, where the line intersects the circle, given the distance from point A to point C. The solution involves using trigonometry to calculate the angles and applying the cosine and sine functions to find the coordinates of point C. The discussion emphasizes the use of triangles and similar triangles to solve the problem effectively.
tomtomtom1
Hello all
I am hoping someone could help shed some light on a surveying problem I am having.
The problem is this:-
• A circle is centered at point B with Known co-ordinates (X2,Y2)
• The circle has a radius which is known (R).
• Point A lays outside of the circle with known co-ordinates (X1,Y1)
• A line is connected between Point A and Point B.
• Point C lays on the line between Point A & B.
• Point C also lays at the exact intersection of where the line and the circle meet.
• The distance between Point A and Point C is known (S).
• All points are in a Cartesian co-ordinate system
Work out what are the co-ordinates of Point C.
I have attached a diagram of the problem.
Can anyone help?
Mathematics news on Phys.org
You should be able to solve this using TRIG
Look at the triangle X2,Y2 X1,Y1, X1,Y2
You can then figure out the angles involved.
Then using similar triangles figure out where point C is :)
Specifically
θ = tan^{-1}((Y1-Y2)/(X1-X2))
then
C_x = cos(θ)*R
C_y = sin(θ)*R
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
