Finding domain and ranges for composition function
10 replies · 4K views · last reply
Coco12
Find the domain and range of (f+g)(x)
Given that
F(x)= 1/(x-1) and g(x) = sqrt(x)
I added the two functions to get 1/(x-1) + sqrt(x)
To get domain, i look at the restrictive x values for both to get x greater than 0 and not equal to 1.
However how do i find the range?
Given that
Another question let's say:
f(x) = x+3
G(x)= -x-4
Find the domain and range of (f*g)(x)
I added the two functions to get 1/(x-1) + sqrt(x)To get domain, i look at the restrictive x values for both to get x greater than 0 and not equal to 1.
Graph both functions separately, preferably using different colors for each graph. Then, using a third color, or a marker pen, go over the parts of the two graphs for which x ≥ 0 and x ≠ 1. From that graph it should be evident what the range of the sum function is.
Coco12 said:
2) I multiplied f(x) and g(x) together to get -x^2-7x-12
My domain I got all real numbers, again how do i get the range?
The graph of the product function is a parabola that opens downward. You should already have a technique for finding the vertex of a parabola. Let's say that the vertex is at (a, b). Then the range will be {y| -∞ < y ≤ b}.
BTW, you misposted this problem in one of the physics sections. This is a precalc type problem, so I moved it to this section.
is there another way to find the range without graphing it?
the answer is y less than -0.7886 or y greater than 2.2287.
How can you get to that precise of an answer when graphing it by hand??
For the second graph (f+g)(x)
The range in the back of the book says y less than .75 but u can see clearly in the graph that it is less than 1 ... What is going on?
Mark44 said:
They're probably using a graphing calculator or some graphing utility.
I drew the graph out it is just a sketch and would not be accurate on the range.. Are you expected to know precisely where it is?
The graphs don't show the sum or difference of the two functions. Those (sum or difference) are the graphs of interest here.
The thing is how do you graph 1/(x-1) + sqrt (x)?
You can get a rough graph by doing it by hand. Pick values of x there are in the common domain for both functions (x ≥ 0, and x ≠ 1), the calculate the y-values.
As I said before, they are probably using a graphing calculator or computer graphics package.
So for example I would take 0.5 and plug it into the composite formula?
