Why Choose Higher Pole Motors If Lower Pole Motors Can Achieve Similar HP?
Higher pole motors, such as 4 or 6 pole designs, are often more expensive and larger than 2 pole motors, yet they provide distinct advantages in performance. While it may seem that a 2 pole motor can achieve similar horsepower (HP) by using gearing or belting, this approach can lead to issues like stalling under heavy loads. The synchronous speed of a motor is determined by its pole count, with 2 pole motors running at 3600 RPM and 4 pole motors at 1800 RPM. A discussion highlighted that a 2 pole motor may not deliver the same power as a 1750 RPM motor, even if both are rated at 1 HP, due to differences in torque characteristics. Understanding these nuances is crucial for selecting the right motor for specific applications.
Froneck
Often I'm reading on other sites that if a 2 pole 3600RPm (synchronous speed) motor were connected so that the ratio would lower the speed to the same as a 4 pole (2X) and so on with 6 pole (3x) the output HP will remain the same. However the larger the number of poles the larger the motor and like wise the cost! If that were so why would anyone want to buy a more expensive 4 or 6 pole motor if the same HP output were available by gearing or belting a 2 pole motor?
I remember when in High School my father bought a lathe for me but the motor had a bad start winding. It was a 1750rpm 1HP single phase motor. Once started the motor ran fine. Getting it started was the problem and done with a rope to pull start it! I went to Sears back when they had all their stuff made in USA and seen that a 3500rpm, 1HPmotor was half the price of a 1750rpm, 1HP motor so I purchased it and belted it down to the same speed. However it did not have the same power as the replaced 1750rpm motor and could be easily stalled with a heavy cut that would not stall the other motor.
Some time later when in Collage I mentioned it to my Electrical Engineering Professor and he showed me why! Been a Loooooong time ago. Can anyone provide me the calculation similar to his.
Frank
You may have been told wrong. A 60 Hz motor needs to run at a speed of 3600/N RPM, where N is the number of pole-pairs. 2 poles=1 pair, 3600 RPM. 4 poles=2 pair, 1800 RPM.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
12K
35K
