Calculating Frequency for Induction Motors with Given Horsepower and Pole Count
To calculate the frequency for an induction motor with 10 horsepower and four poles, the synchronous speed (ns) can be determined using the formula ns = 120 * frequency / number of poles. The rated speed of the motor is typically within 5% of the synchronous speed. The formula for induced torque is given as Pgap / Ws, where Ws requires the frequency for calculation. In engineering, answers that are within 10% of the expected value are generally considered acceptable. Understanding these principles is crucial for accurate motor performance analysis.
onceinalifetim
Hello
I'm doing a question in induction motor now.
formula for Induced torque is Pgap / Ws.
i have found the Pgap, but in order to find Ws, i need frequency to find ns..
so my question is, how to find frequency with only given 10hp and four pole
The rated speed of an induction motor is typically within 5% of that motor's synchronous speed. http://www.engineeringtoolbox.com/speed-electrical-motors-d_738.html
Broadly speaking, in engineering, an answer correct to within 10% is generally acceptable. There are always exceptions to rules of thumb, but I can't see the question under discusion being one of them. :smile:
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
