Feynman propagator and particle uniqueness
johne1618
In his layman's guide to QED Feynman defines a particle propagator as a function that gives you the amplitude that a particle, that was initially at spacetime event ##x##, will be found at spacetime event ##y##.
But does this definition assume that the particle is unique so that if you find it at the spatial coordinates of ##y## then you are automatically guaranteed that it is no longer at the spatial coordinates of ##x##?
As particles are indistinguishable maybe the propagator only specifies the amplitude that, given a particle is at event ##x##, then an *additional* particle of the same type will be found at ##y##.
In that case maybe one also needs to apply a reverse propagator that gives the amplitude that an antiparticle will be found at ##x## given that a particle was found at ##y##?
Perhaps this would destroy the original particle at ##x## and so ensure that we are only left with a particle at ##y##.
Does this make sense?
The introductory quantum mechanics is a single particle theory.I urge you to check that Feynman is talking about a single-particle problem or not.Things get different where the number of particles gets bigger than one.
The propagator does not act on a particle, but on a field. The amplitude you are talking about is related to this field. The particle interpretation is not based on propagators.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
