Finding Flaw in Reasoning: Complex Fun
In summary, the mistake in the given reasoning is in assuming that \frac{\sqrt{-1}}{1} = \frac{\sqrt{4}}{\sqrt{-1}}, and then multiplying both sides by i without considering the implications of this assumption. This leads to the incorrect statement that \frac{1}{i} = -i, when in fact, according to standard definitions, \frac{1}{i} = i. The root of the problem lies in the fact that every complex number has two square roots, and the square root operator must choose only one of them in order to be well-defined. Therefore, we must carefully consider the domain of the square root operation when working with complex numbers.
quasar987
32
Find the flaw in the following reasoning:
[tex]-4 = -4[/tex]
[tex]\frac{-4}{1} = \frac{4}{-1}[/tex]
[tex]\sqrt{\frac{-4}{1}} = \sqrt{\frac{4}{-1}}[/tex]
[tex]\frac{\sqrt{-4}}{1} = \frac{\sqrt{4}}{\sqrt{-1}}[/tex]
[tex]\frac{\sqrt{-1}\sqrt{4}}{1} = \frac{\sqrt{4}}{\sqrt{-1}}[/tex]
[tex]\frac{2i}{1} = \frac{2}{i}[/tex]
[tex]2i^2 = 2[/tex]
[tex]-2 = 2[/tex]
It's clear that the equality [itex]\frac{2i}{1} = \frac{2}{i}[/itex] is wrong because on the LHS we have a complex number (of the form a + ib) but the RHS is not. But the real flaw is probably higher. Any idea?
Mathematics news on Phys.org
the mistake is in passing from the 3rd to last to the 2nd to last line:
namely, you multiply both sides by i and cancel
[tex]\frac{i}{i} \neq 1[/tex]
it is -1.
How do you show that?
Also, how do you show that
1/i = -i ?
The domain of the square root operation must be kept to fractions in which only the numerator can be negative in order for it to be well-defined for negative real numbers, ie. to be explicit, your real number must be in the form [tex] a/b, \ a \in \mathbb{R}, \ b \in \mathbb{R}^+/\{0\}[/tex]. Here's something simpler, that also appears to work, but is wrong for the same reason:
[tex]i = \sqrt{-1} = \frac{\sqrt{1}}{\sqrt{-1}} = \frac{1}{i} \Longrightarrow 1=-1[/tex]
The root of the problem is that
[tex]\frac{1}{i}=i[/tex]
is not valid according to common definitions. In fact, using standard definitions, you get
[tex]\frac{1}{i} = -i,[/tex]
instead, since
[tex]\frac{1}{i} = \frac{1}{i}\cdot \frac{-i}{-i} = \frac{-i}{1} = -i.[/tex]
[tex] \frac{i}{i} \neq 1[/tex]
it is -1.
This is wrong.
As you get quite quickly from my last post,
[tex] \frac{i}{i} = i \frac{1}{i} = i(-i) = 1.[/tex]
As a matter of fact, the whole purpose of this is to make sure (well, in fact we assume it, in order to make the complex numbers into a nicely organized field) that
[tex] \frac{i}{i} = 1.[/tex]
The REAL root of the problem, of course, is that every complex number has two square roots, and the square root operator must choose only one of them to give you if it is to be well-defined. We then need to choose which "nice" properties we want the operator to keep, and typically, we choose those I have mentioned above.
It might have something to do with the fact that [(-1)^(1/2)]*[(-1)^(1/2)] does not equal [(-1)*(-1)]^(1/2) which equals 1^(1/2), because we know by definition of i that [(-1)^(1/2)]*[(-1)^(1/2)] should equal -1.
Sorry for the ugly equations; I don't know how to make the fancy things you guys can do.
EDIT: Uh, never mind, those posts just before mine made sense...
First off,
[tex]\frac{1}{i} = -i[/tex]
To see this, I'd first like to point out:
[tex]\frac{1}{z}[/tex]
is just notation for: The number which is the multiplicative inverse of [itex]z[/itex].
In otherwords, 1/z is that number which when multiplied by z gives 1, ie-
[tex]z\frac{1}{z} = 1[/tex]
That being said
[tex]i^2 = -1[/tex]
[tex]i\cdot i = -1[/tex]
[tex]-1 \cdot i \cdot i = (-1)(-1)[/tex]
[tex]( -i )(i) = i \cdot (-i) = 1[/tex]
Therefore,
by the above argument
That's fine (I posted it already above). But your earlier statement,
[tex]\frac{i}{i} \neq 1,[/tex]
is wrong (as you in fact showed in your post directly above this one).
joeboo said:
First off,
That being said
[tex]i^2 = -1[/tex]
Therefore,
haha ok it's that simple.
The fundamental error is writing [itex]\sqrt{-1}= i[/itex]. -1, like any number has two roots. In the real numbers, we can distinguish between the positive and negative roots. Since the complex numbers cannot be ordered, we cannot do that in general. It is better to define complex numbers as pairs of real numbers (a, b) defining sum (a,b)+ (c,d)= (a+c,b+d) and product (a,b)*(c,d)= (ac- bd,ac+bd). Using that definition, the "paradox" disappears.
Heh. I made an error, fixed it, and didn't realize the error. :blushing:
Thanks for pointing it out so kindly ( honest )
it is -1.
As far as I know, x over x cancels out to positive one, not negative
[tex]\frac{x}{x} = \Big \{ \begin{array}{cr} 1 & x \neq 0 \\ \mbox{undefined} & x=0\end{array}, \ x \in \mathbb{C}[/tex]
1. What is "Finding Flaw in Reasoning: Complex Fun"?
"Finding Flaw in Reasoning: Complex Fun" is a game designed to help players improve their critical thinking skills by identifying flaws in arguments and logical reasoning. It presents players with complex scenarios and challenges them to find the flaws in the reasoning presented.
2. How does "Finding Flaw in Reasoning: Complex Fun" help improve critical thinking?
The game helps players improve their critical thinking by providing them with opportunities to practice identifying flaws in reasoning and strengthening their ability to analyze complex arguments. It also encourages players to think critically and creatively in a fun and engaging way.
3. Who can benefit from playing "Finding Flaw in Reasoning: Complex Fun"?
Anyone can benefit from playing this game, as critical thinking skills are valuable in various aspects of life such as decision making, problem solving, and communication. It can be particularly useful for students, professionals, and anyone looking to improve their critical thinking abilities.
4. Is "Finding Flaw in Reasoning: Complex Fun" suitable for all ages?
Yes, the game is suitable for all ages. It can be played by children, teenagers, and adults alike. However, it may be more enjoyable and beneficial for older players who have a better understanding of complex arguments and logical reasoning.
5. Are there any other benefits of playing "Finding Flaw in Reasoning: Complex Fun"?
Aside from improving critical thinking skills, playing this game can also help develop other important skills such as problem solving, decision making, and communication. It can also be a fun and engaging way to challenge oneself and improve cognitive abilities.
  • General Math
