Calculating Resistivity of Doped Si: P and As Substrate Comparison"
  • Thread starter Thread starter liquidFuzz
    Resistivity Si
To calculate the resistivity of doped silicon with both P and As substrates, the mobility should be derived from a curve based on the total doping concentration rather than using a simple formula like μ_n(N_d + N_d). The total concentration, N_{tot}, should account for both dopants, but typically one species will dominate the concentration. Thus, using the highest dopant concentration in the region will yield a more accurate result. For precise calculations, refer to resources that detail the relationship between mobility and doping concentration.
liquidFuzz
How do I calculate the resistivity of a doped Si if I have to substrate of the same type. Let's say a P and As doped Si. Is the mobility given by, \mu_n(N_d + N_d), or should I do this in an other way? Further, when I calculate the resistivity, is the concentration, N_{tot} = N_d(P)+N_d(As)?
Thanks!
The mobility itself is a complicated function of the doping concentration and it depends on the total dopant, not on just Nd or Na. So the way to do it is to get the mobiliity off a curve based on the total doping concentration and then calculate the resistivity using the standard formula. Typically the concentration is completely dominated by one species over another so the answer won't change much as long as you use the highest dopant concentration in the region. This webpage explains the process: http://ecee.colorado.edu/~bart/book/mobility.htm
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
