Expression of fields in Faraday rotation
EmilyRuck
Hello!
Talking about propagation of an electro-magnetic field in a non-isotropic medium, I've got some troubles with the expression in object, used to show the Faraday rotation of the polarization of a field.
An electro-magnetic field enters a particular medium, propagating along the \hat{\mathbf{u}}_z direction. In z = 0, its electric field is \mathbf{E} = E_0 \hat{\mathbf{u}}_x. It could also be written as a superposition of two circularly polarized waves:
\mathbf{E} = \displaystyle \frac{E_0}{2} (\hat{\mathbf{u}}_x + j \hat{\mathbf{u}}_y) + \displaystyle \frac{E_0}{2} (\hat{\mathbf{u}}_x - j \hat{\mathbf{u}}_y)
The two components have different propagation constants, β_- and β_+, in the medium. In a generic z position we could write
\mathbf{E} = \displaystyle \frac{E_0}{2} (\hat{\mathbf{u}}_x + j \hat{\mathbf{u}}_y)e^{-j β_- z} + \displaystyle \frac{E_0}{2} (\hat{\mathbf{u}}_x - j \hat{\mathbf{u}}_y)e^{-j β_+ z}
Rearranging the last expression (this is done in several books, like Pozar), we obtain:
\mathbf{E} = E_0 e^{-j (β_+ + β_-) \frac{z}{2}} \left\{ \hat{\mathbf{u}}_x \cos \left[ \left( β_+ + β_- \right) \displaystyle \frac{z}{2} \right] - \hat{\mathbf{u}}_y \sin \left[ \left( β_+ - β_- \right) \displaystyle \frac{z}{2} \right] \right\}
This is done to show that the polarization is still linear like in the original field \mathbf{E} = E_0 \hat{\mathbf{u}}_x, but its "orientation" has changed with the position z.
But could this still be called a wave? Its dipendence from z is no more only in the exponential e^{-j β z}, but is also contained in the cosine and sine terms.
It apparently does no more satisfy the Helmholtz wave equation, because deriving the x component with respect to z gives a completely different result that that obtained deriving the same component with respect to time (assuming that we are using phasors).
So, how can I interpret this expression? Shouldn't it still satisfy the Helmholtz equation? Shouldn't it be still a wave?
Thank you for having read,
Emily
Hello.
You started with a superposition of two circularly polarized that propagate with different wavenumbers ##\beta##.
Each of these satisfy a Helmholtz equation. But ##\beta## appears in the form of the Helmholtz equation. So, the two individual circularly polarized waves satisfy different Helmholtz equations.
Try to show that the sum of the two circularly polarized waves cannot satisfy a Helmholtz equation.
Does the superposition of the two circularly polarized waves represent a wave in the medium? That depends on the definition of a wave. If you define a wave loosely as "a disturbance in a medium that propagates" or something like that, then I would say you have a wave. If you define a wave to be "a mathematical expression that satisfies the wave equation ##\psi_{,xx} - \frac{1}{v^2}\psi_{,tt} = 0## for some ##v##", then you do not have a wave. That's because each component satisfies a different wave equation (with different value of ##v##), so the sum of the components does not satisfy the wave equation. But that would be true anytime you have a superposition of waves of different wavelength propagating in a dispersive medium.
Likes 1 person
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
