What is the effective interest rate per period for compounding semiannually?
The discussion focuses on calculating the effective interest rate for a loan with a nominal annual rate of 5% compounded semiannually. The effective interest rate per period is determined by dividing the nominal rate by the number of compounding periods, resulting in 2.5% every six months. However, compounding this rate leads to an actual annual interest rate of approximately 5.0625%, which is higher than the nominal rate. Participants clarify that the nominal rate can be misleading, as it does not accurately reflect the true cost of borrowing. Understanding these distinctions is crucial for borrowers to grasp the real implications of interest rates.
ainster31
I have borrowed $100. The interest rate is 5% per year compounded semiannually. How much will I have to pay the bank after 1 year?
##F=P(1+i)^{ n }##, where i is the effective interest rate per period and n represents the number of periods
How do I get the effective interest rate per period?
Shouldn't that just be the nominal annual rate (5%) divided by the number of compounding periods? What's the number of periods here?
The textbook says that 5% interest every year compounded semiannually is the same as 2.5% interest every 6 months. But I don't understand how they're equivalent. How can you just divide by two?
Because this is apparently how economists and finance people think.
The 5% is called a 'nominal' *annual* rate. Dividing it by the number of compounding periods gives you an 'effective' *period* rate. Applying an exponential formula to it will give you the 'effective' *annual* rate.
That 5% quoted to you is actually a "fake" rate, meant to lull you into a false sense of security. The 2.5% every 6 months is a real thing, and it's simple to work out the actual compound interest you'll be paying at the end of the year. When you do the calculation, you'll find it's actually a little higher than 5%. That's basically how they pull the wool over your eyes when you take a loan without realising how much you'll actually end up owing. Of course, it works in your favour if you're actually investing and those are returns rather than a debt you're repaying.
You can look all this up easily on the web. It's just a matter of getting used to the (dumb) terminology.
Likes 1 person
Ah, that explains why there were no formulas that dealt with nominal interest rates - only effective interest rates. Thanks for the clarification.
You are right to be confused: 2.5% compounded twice produces a true annual interest rate of about 5.0625%. Nevertheless, the convention suggested in your problem is the one that is used throughout the banking and finance industries. So, a mortgage with 12% annual rate, compounded monthly, yields 1% per month---by the definitions of the financial world---which amounts to an 'actual' annual rate of about 12.6825%.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
