Electricity and Air: A Fascinating Interaction
A bird can safely perch on a high power line because it does not create a potential difference between itself and the line, unlike a person who touches the line while grounded. The air acts as an insulator, preventing electric current from flowing between the line and the bird, despite the presence of an electric field. The breakdown voltage of air is significantly higher than the voltage of typical transmission lines, which prevents arcing. If transmission lines were grounded through the air, it would lead to dangerous discharges affecting nearby objects. Therefore, while birds can safely sit on a line, larger animals touching multiple wires could experience fatal shocks.
phymathlover
A bird perches on a bare high power line and nothing happens to it. A man standing on the ground touches the same line and gets a fatal shock. This is supposed to be because there is potential difference between the ground and the line which the man touches but similarly, isn't there also a potential difference between the line and the air to which the bird is exposed and thus a potential difference and so shouldn't the bird also get a shock? I know that air is an insulator but since the high transmission lines have large electric fields around them so this should cause breakdown of air?
The breakdown voltage for air is much larger than the line voltage. The field strength for the breakdown of air is greater than 3 MV/m. If electric transmission lines grounded with the air, it would be impossible to transmit electricity in this fashion without zapping everything near the lines.
Also note that you, as a person, are not a great insulator ... and being the path of least resistance is from the line voltage thru you to the ground.
If a bird is big enough to touch two wires simultaneously you will get roast buzzard!
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
