Heavy question; the gravity of a thought experiment
The discussion explores how local gravitational variations, influenced by the density of underground rock formations, affect gravity at specific locations. A thought experiment involving a Ferris wheel positioned over a cliff raises questions about whether the lack of Earth beneath one side would create a significant gravitational imbalance. However, it is concluded that gravity pulls in all directions uniformly, meaning the weight distribution would not cause the wheel to spin. The energy conservation principle indicates that lifting and dropping weights would yield equal energy regardless of the wheel's position. Ultimately, the gravitational effects in this scenario are negligible and would not result in noticeable movement.
mjhilger
Just thinking about gravity. How is the gravity effected by the surroundings of a location?
Suppose we have a giant farris wheel with very good bearings and we place it in a location; like the Grand Canyon - somewhere with a very steep dropoff; such that say 40% of the wheel is over the cliff. So the buckets that cross the boundary of the cliff have no Earth below them for say 2500 feet at least; while the other side is positioned over solid rock/earth. Would there be a large enough difference in the delta of the gravity to cause a spin from the buckets over the solid Earth having more pull? I have not worked out the math yet, just a ponder?
Thanks,
Mitch
The local gravitational field varies with the density of local/underground rock formations. Mining companies have been using this information as part of their scientific prospecting technique since Eötvös developed practical devices. See the Wikipedia article on Eötvös.
But is it enough to move something besides the most delicate of balances? The answer is not so that anybody would notice.
Gravity doesn't just pull in one direction, it pulls in all directions. So you can't prevent the ground underneath the ferris wheel from pulling on the entire ferris wheel.
Of course not. Energy is conserved. It takes as much energy to lift a bucket as you get from dropping a bucket. It doesn't matter if you lift it in some zig-zag direction or straight up.
No one side of the wheel would be attracted more than the other, so it would just stop.
Say it was a very sensitive beam balance hanging over the cliff with equal weights one end would go down and the other up and then stay there what makes you imagine it would spin.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
