Find Limit of n*(x^(1/n)-1)-ln(x) for Any n
  • Thread starter Thread starter bobby2k
    Limit
bobby2k
Find the limit:
lim_{x -> \infty}[n*(x^{\frac{1}{n}}-1)-ln(x)], for any n.
L'Hopitals rule.
I know that the ratio of the first expression over the last goes to zero, by L'Hopital, but unfortunately I now have a difference and not a quotient. Is it possible to transform it in some way to use L'Hopital?
a-b = (ab-b^2)/b = (a/b - 1)/(1/b)
Not sure if one of those helps.
##y = \displaystyle \lim_{x \to \infty}(ln[e^{n*(x^{\frac{1}{n}}-1)}]-ln(x))##
##y = \displaystyle \lim_{x \to \infty}\displaystyle ln\left[\frac{e^{n*(x^{\frac{1}{n}}-1)}}{x}\right]##
##e^y = \displaystyle \lim_{x \to \infty}\displaystyle \left[\frac{e^{n*(x^{\frac{1}{n}}-1)}}{x}\right]##
That gives it in fraction form. I'm not sure if it makes it easier to evaluate or not, I haven't tried the problem myself.
If you apply l'Hopital's rule on that fraction, you end up with the same fraction again (plus some irrelevant part you can ignore).
You're right.
I believe factoring out ln(x) so you have ##\displaystyle\lim_{x\to\infty}\ln{(x)} \cdot \left(\frac{n(x^{1/n}-1)}{\ln{(x)}} - 1\right)## might work. You can use l'Hospital's on the inside fraction which works better than what I suggested above.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
