Is energy and mass extraction possible within the Kerr Black Hole Ergosphere?
Philosophaie
In a Kerr Black Hole there exists a region called the Ergosphere.
It is between the Event Horizon and a spheriod called the Static Limit.
The Event Horizon can be simplified to: ##\Delta## = 0.
The Static Limit can be simplified to: ##g_{tt}## = 0.
They yield two separate spheres the Static Limit being greater.
Is it theoretically possible to extract energy and mass from the black hole in this region?
Particles within this ergosphere must co-rotate with the inner mass if they are to retain their time-like character.
http://en.wikipedia.org/wiki/Ergosphere
Numerical relativity solving einstein's equations - baumgarte t w , shapiro s(isbn 052151407x)
The spin is restricted to the range 0 ≤ a/M ≤ 1 where a=J/M, M=G*Mass/c^2, G is Gravitational Constant and c is speed of light.
"The rotating black is stationary and axisymmetric, hence the spacetime possesses two Killing vectors ##\delta_t## and ##\delta_\phi##".
I believe the Killing Vectors arise from the mixed components of the Metric?
Test particles moving in the field of a rotating black hole conserve their energy E = ##−p_t## and
axial component of angular momentum J = ##p_\phi##.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
