What is the force direction on a left wire in a parallel current setup?
  • Thread starter Thread starter ivanwho49
    Currents Parallel
In a parallel current setup with two wires, the direction of the force on the left wire can be determined using the right-hand rule, which relates the current direction to the resulting magnetic field and force. The confusion arises from identifying the correct wire positions, as the top wire is referred to as the left wire in the discussion. The right-hand rule requires the direction of the current to establish the magnetic field's influence on the left wire. Clarification is needed on which right-hand rule applies, as there are variations depending on the context. Understanding these principles is essential for solving the problem accurately.
ivanwho49
Two current carrying wires run parallel. The bottom wire creates a magnetic field at a point on the top wire. What direction is the force on the left wire?
I'm assuming there's no equation, just the right hand rule..?
I think this problem asks for the right hand rule, but I'm not sure. I don't have a very good grasp of the right hand rule... I'm assuming it is dependent on the direction of the magnetic field and something else.
Please help!
Hi ivanwho49. I see a top wire and a bottom wire...but where's the left wire? :confused:
The right-hand rule sounds good!
Sorry, I meant top. Top = left. What two things do I use the right hand rule with though?
There are two different "right-hand rules". Use the right one first, it needs only one "thing", viz., direction of current.
