Building a Water Bottle Xylophone: Calculating Notes Using Physics Equations
  • Thread starter Thread starter cjmiba324
    Water
cjmiba324
I am now doing my physics project, which is to build an instrument. I choose mine to be glass bottles filled with water and hit them like an xylophone. But our physics teacher requires us to write down the calculation process of finding each note.
He only taught us the formula frequency(n)=nVelocity/2L. But I think this formula is only used when I blow the bottles not hit them. Should I use this formula to get the notes or is there another formula that I can use?
So what have you done with these bottles so far ? Any experimental evidence that the tones are dependent on the water level when you hit the bottles ? Same question for when you blow on the opening ?
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
