Trig Equation: Is This Procedure Correct?
The procedure presented for solving the equation A sin(ωt) = A sin(φ) is incorrect. It is noted that the correct relationship is φ = ωt + k(2π), where k is an integer, rather than φ = ωt. The oscillatory nature is attributed to the sine function itself, not merely to the argument φ. Therefore, it is misleading to claim that φ = ωt is oscillatory. The sine function, sin(φ), is what exhibits oscillation, not the variable φ alone.
alejandrito29
Is correct the following procediment?
## A \sin (\omega t) = A \sin (\phi) \to \phi= \sin^{-1} \sin (\omega t )##
Is correct to say that ## \phi = \omega t## is oscillatory in this case ??
Mathematics news on Phys.org
You don't need inverse trig functions here. We can ignore A, assuming that it is a nonzero constant.
If sin(ωt) = sin(θ), then θ = ωt + k(##2\pi##), where k is an integer.
But you certainly cannot "say that \phi= \omega t is oscillatory"! It is the function sin(\phi) that is oscillatory, not just the argument, \phi.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
