What is the solution for object distance in a diverging lens?
  • Thread starter Thread starter ghostops
    Lens Thin lens
The discussion focuses on solving for the object distance in a diverging lens with a focal length of -15 cm and a magnification of 5/9. Participants emphasize the importance of correctly applying the magnification and thin lens equations to derive the object distance. Several algebraic errors are identified in the attempted solutions, leading to incorrect results. The need for clear step-by-step calculations is highlighted to pinpoint mistakes. Ultimately, the conversation underscores the necessity of careful algebraic manipulation in optics problems.
ghostops
Now consider a diverging lens with focal length f=−15cm, producing an upright image that is 5/9 as tall as the object.
What is the object distance? You will need to use the magnification equation to find a relationship between s and s′s′. Then substitute into the thin lens equation to solve for s.
1) M = -s'/s
2) 1/s+1/s'=1/f
using equation 2 I solved for s' then subsituted that into equation 1 and solved for s and from that put it back into equation s and solved for s and ended up with the answer of -65/3.
However this was the wrong answer and do not know what I did wrong.
And what did you get? Show exactly what you substituted into the equation.
Ditto.
Double ditto. (Well, you've told us the answer you got, but we still need to see exactly how you got it.)
It's hard for us to tell you what you did wrong, if you don't tell us exactly what you did. If you show us all the steps explicitly, we can tell you which step went wrong.
step 1: s = (1/f-1/s')^-1
step 2: m=-s'/((1/f-1/s)^-1)
m=-s'(1/f-1/s)
m=-(s'/f-1)
(f/s')m=1
f/s'=1/m
f=s'/m
s' = f(m)
step 3: 1/s+1/fm=1/f
1/s=1/f-1/fm
s=(f-fm)^-1
Double check your algebra. There is at least one fairly serious mistakes there. In step 2, how did you get from the third line to the fourth line?
step 2: m=-s'/s=-s'/((1/f-1/s)^-1)
Check this step carefully. I added an intermediate step in red to (hopefully) make the error more obvious.
yeah I see it now
so starting my from my mistake
m=-s'/s=-s'/(f-s') = (-s'/f)-(s'/-s)'
m = -s'/f+1
m = -s'/f+1
m-1=-s'/f
fm+-f=-s'
-fm+f=s'
1/s-1/fm+f=1/f
1/s=1/f+1/fm-f
1/s = 1/f + 1/fm -1/f
s=(fm)^-1
No, the part that I put in red isn't true. What you're trying to do here is similar to 1/(a-b) = 1/a - 1/b, which doesn't work. (Try it with a numerical example if you need to convince yourself.)
ghostops said:
yeah I see it now
m = -s'/f+1
m = -s'/f+1
m-1=-s'/f
fm+-f=-s'
-fm+f=s'
1/s-1/fm+f=1/f
1/s=1/f+1/fm-f
s=(fm)^-1
how did you go from -fm+f=s'
to 1/s-1/fm+f=1/f ?
You 're making too many silly algebra mistakes. You need more practice.
