What Is the Probability of Finding a Particle in the Interval [0,d]?
Nugso
Suppose we have a particle in 1-dimension, with wavefunction Ae^{-\frac{|x|}{2d}} . What is the probability to find the particle in the interval [0,d]?
Please provide your answer in terms of A, d, mathematical constants such as π (entered as pi) or e (entered as e). (Assume that A is real)
∫ψ²dx = 1
I think I need to find A by normalizing it. ∫ψ²dx = 1
By integrating it, I get A= 1/\sqrt{2d}
Now, I have to integrate it again, but this time with the interval of [0,d]
∫1/sqrt(2d)*e^{-\frac{|x|}{2d}}*1/sqrt(2d)*e^{-\frac{|x|}{2d}}dx
and the answer I'm finding is, 1/2*(1-e^{-1/d})*d
But somehow the answer is wrong. How do I correct it?
I would check your solution for A again.
Likes 1 person
∫ψ²dx = 1
Check it again. How did you wind up with a -1/d in the exponent?
Likes 1 person
Sorry for the late reply. I checked it and corrected the mistake.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
