General Relativistic Effects on an Electro-Magnet
jartsa
Let's say there's a current going around in a superconducting loop in vacuum. Then the loop gets buried in huge amount of matter, which has the same magnetic susceptibility as vacuum. (when not affected by gravity the matter has the same magnetic susceptibility as vacuum)
Will the magnetic field change near the loop?
Will the magnetic field change far away from the loop?
Yes. The magnetic field is coupled to the connection which is itself coupled to the gravitational field.
Likes 1 person
Model the "huge amount of matter" as a spherical shell of mass M and radius R, and consider the situation before the current loop is introduced. Outside the shell the field will be Schwarzschild, with metric
ds2 = (1 - 2M/r) dt2 - (1 - 2M/r)-1 dr2 - r2 d2Ω
Inside, the field will be flat. The boundary condition at the shell is that its intrinsic curvature must be the same as viewed from inside and outside. Choose inner coordinates to match the outer ones. What's different is grr. The inner metric will be
ds2 = (1 - 2M/R) dt2 - dr2 - r2 d2Ω
which is just the Minkowski metric with a rescaled t coordinate.
Now introduce the current loop. The B field will be continuous across the shell, so both inside and outside, the B field is that of a magnetic dipole. However the dipole moments differ, because an inside observer will rescale his t coordinate to match Minkowski.
The result is simply time dilation - from the outside the currents appear slower. The external effect of the mass shell is a reduced apparent magnetic dipole, and correspondingly a B field that is reduced.
Likes 1 person
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
