Does the Order of Resistor and LED Affect Circuit Performance?
The order of a resistor and LED in a series circuit does not affect circuit performance, as current remains the same throughout the circuit regardless of component arrangement. The LED's forward voltage drop is constant, but the resistor limits the current, which can vary based on its value. Using a high resistance, like 100kΩ, with a 9V supply will likely result in insufficient current to illuminate the LED. For optimal brightness at 20mA, a resistor value between 4.7kΩ and 10kΩ is recommended. Understanding the behavior of current flow and voltage drops is essential for effective circuit design.
alexmath
Hi, I've been struggling to find the answer to this questions, which are probably simple ones.
Does it matter what order a resistor and LED ( or any component ) are in. For example:
Vcc -----resistor------Led------gnd
or
Vcc ------led-------resistor------gnd
Are they the same? If so why?
I don't quite get how electrons know what is coming next after hitting the first resistor for example in a voltage divider.
Second ones:
Let's assume that an ( a led or an led? EEE LEEE DEE ? ) led has a forward voltage drop of 3v, and a voltage supply at 9v. No matter what resistor do i choose, the forward voltage drop on the led should be the same, but the current should vary right? which in practice isn't close at all...
Should i expect in this case: 9v VCC -------- 100kΩ ------- LED (3v) ----- GND to have 3v on the led, 6v on the resistor and very very tiny current such that the led would not possible glow?
But if we push 20ma of current through the led with less then 3v. Will the led get bright?
Thanks for your time in advance, hope there are not stupid questions.
Order of elements in a serial path is irrelevant.
Electrons of course don't "know" what coming up and in any case it does not matter since the actual speed of electron drift in a current is negligible (some like a meter a second, maybe slower). Current flow is like a chain. You pull the chain a little and all the links move by the same amount. Same thing with electrons in a current, with the "chain" moving really slowly.
Because the current flowing in a series circuit will be the same, regardless of where it is measured
Note also ... tho the resistor does produce a voltage drop, its primary purpose is to limit current to the LED
Ohhh and your example of a 9V supply, a 100k resistor and a LED
The LED isn't likely to light up, or if it does it will be very faint ... for a 20mA, 3V LED and a 9V supply you will need somewhere ~ 4k7 to 10k for an avg brightness
work through the formula and examples in the link given to you by UltrafastPED
cheers
Dave
How do things 'know'?
That's the question that comes into everybody's head at some early stage in their electrical studies. The fact is that it takes time for circuits to settle down. An electromagnetic pulse travels around and along a DC circuit when it's first turned on. All the elementary questions deal with what happens after a steady state has been reached. Yes, the resistors nearer the battery may well have more instantaneous current flowing, at switch on, but that's of no concern to 'the student' or even the regular DC circuit designer.
Consider the time when you played at damming a stream, as a child. It could take many minutes for the flow to settle down over all the weirs and through all the holes. Same thing with DC electrics. All circuits have bits of inductance and capacitance in them (not necessarily in the form of soldered in components - just in the layout).
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
