What are the velocities of two objects after they collide?
  • Thread starter Thread starter Niko Bellic
In a collision between two equally massive objects moving toward each other, the outcome depends on whether the collision is elastic or inelastic. Momentum conservation dictates that the total momentum before and after the collision remains constant, but without knowing if kinetic energy is conserved, multiple outcomes are possible. In a perfectly elastic collision, both objects bounce back at the same speed they approached, while in a perfectly inelastic collision, they come to a complete stop. The discussion also touches on the forces exerted during collisions, noting that the impulse and change in momentum vary based on the type of collision and the duration of contact. Ultimately, the specific velocities after the collision hinge on the nature of the collision itself.
Niko Bellic
Let's say two equally massive objects move toward each other at equal velocities (let's use 30 kg and 5 m/s for the sake of having some numbers).
Will the objects bounce off of each other or will they both stop in place? If they bounce off each other, at what velocity?
The momentum conservation principle suggests that the overall momentum (mass*velocity) of the two objects should remain the same before and after collision (i.e., momentum gained by one object should be equal to the momentum lost by the other).
This still leaves room for ambiguity in resulting velocities. For instance, here's a solution where one object gains 150 units of momentum and the other loses 150 units, causing both objects to stop.
Code:
		[B]MOMENTEM[/B]		[B]MOMENTUM[/B]
		[B]BEFORE COLLISION[/B]	[B]AFTER COLLISION[/B]
[B]OBJECT A[/B]	(30kg)*(+5m/s)=150	(30kg)(0m/s)=0
[B]OBJECT B[/B]	(30kg)*(-5m/s)=-150	(30kg)(0m/s)=0
[B]OVERALL[/B]		0			0
Here's another valid solution where one object gains 225 units of momentum and the other loses 225 units, causing the objects to bounce off each other and head back from where they came from.
Code:
[B]OBJECT A[/B]	(30kg)*(+5m/s)=150	(30kg)(-2.5m/s)=-75
[B]OBJECT B[/B]	(30kg)*(-5m/s)=-150	(30kg)(2.5m/s)=75
[B]OVERALL[/B]		0			0
But there's only one right solution, right? What is it? What other contraint besides momentum conservation am I missing?
How would one mathematically calculate the actual resulting velocities?
Thanks a ton!
Energy.
Is kinetic energy conserved, or is some energy lost as heat, sound, etc.? Without that information, there is no unique answer.
See
Aha! Thanks! So it depends on whether the collision is elastic or inelastic, which tells you whether kinetic energy is conserved or not. Assuming a perfectly elastic collision, our new velocities for the collision described in my original post would be would be
<br /> v_{1}=\frac{u_1(m_1-m_2)+2m_2u_2}{m_1+m_2}=v_{1}=\frac{+5(30-30)+2*30*(-5)}{30+30}=-5\\<br /> <br /> v_{2}=\frac{u_2(m_2-m_1)+2m_1u_1}{m_1+m_2}=\frac{-5(30-30)+2*30*(+5)}{30+30}=+5<br />
which makes sense intuitively: the objects bounce back at the same speed at which they came.
For a perfectly inelastic collision, the coefficient of restitution is 0, causing both objects to just stop when they hit each other.
For a collision that's neither perfectly inelastic or elastic, the objects bounce back at some speed less than 5 m/s
Okay, so I got a FOLLOWUP QUESTION
What force do the objects exert on each other in the different kinds of collisions?
Here's my attempt at answering my own questions:
Impulse = \int F dt = change In Momentum = mv_1-mu_1
For an elastic collision, the change in momentum for one of the objects is is 30*5-30*(-5)=300
For an inelastic collision, the change in momentum for one of the objects is is 30*5-30*(0)=150
In either case, the force depends on how long the collision is. Well, how long is it? I have no idea. Also, force throughout the contact might not necessarily be constant either right?
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
