What is the uncertainty principle
The Uncertainty Principle is derived from the properties of non-commuting Hermitian operators, expressed mathematically as the inequality relating the variances of two observables. The key equation states that the product of the variances of two operators A and B is greater than or equal to a quarter of the square of their commutation relation. This principle highlights that simultaneous measurements of non-commuting observables, such as position and momentum, inherently involve uncertainty. The specific case of position and momentum leads to the well-known form of the Uncertainty Principle, \langle (\Delta x_i)^2 \rangle \langle (\Delta p_i)^2 \rangle \geq \frac{1}{4} \hbar^2. Understanding this principle is crucial in quantum mechanics, as it underscores the limitations of measurement at the quantum level.
Definition/Summary
This is a derivation of the Uncertainty Principle based on the properties of non-commuting Hermitian operators.
Equations
\langle (\Delta A)^2 \rangle \langle (\Delta B)^2 \rangle \geq \frac{1}{4} |\langle [A,B] \rangle | ^2
\langle (\Delta x_i)^2 \rangle \langle (\Delta p_i)^2 \rangle \geq \frac{1}{4} \hbar ^2
Extended explanation
Let A, B be a pair of operators. We define \Delta A \equiv A - \langle A \rangle I, where the expectation value of A with respect to some state |a \rangle, is defined as \langle A \rangle = \langle a | A | a \rangle. This number tells you what A will be measured as, on average, over several repeated measurements performed on the system, when prepared identically.
Now, we define an important quantity: the variance or mean square deviation, which is \langle ( \Delta A ) ^2 \rangle. This quantity is no different from the variance in any statistical collection of data. Plugging in from above
\langle ( \Delta A ) ^2 \rangle = \langle (A - \langle A \rangle I)^2 \rangle = \langle A^2 \rangle - \langle A \rangle ^2 ~~~-~(1)
Let |x \rangle be any arbitrary (but normalized) state ket. Let
|a \rangle = \Delta A ~ |x \rangle
|b \rangle = \Delta B ~ |x \rangle
First we apply the Cauchy-Schwarz inequality (which is essentially a result that is two steps removed from saying that the length of a vector is a positive, real number): \langle a |a \rangle \langle b |b \rangle \geq | \langle a |b \rangle |^2, to the above kets (keeping in mind that \Delta A~, ~\Delta B are Hermitian), giving
\langle (\Delta A)^2 \rangle \langle (\Delta B)^2 \rangle \geq |\langle \Delta A \Delta B \rangle | ^2 ~~~-~(2)
Next we write
\Delta A \Delta B = \frac{1}{2}(\Delta A \Delta B - \Delta B \Delta A) + \frac{1}{2}(\Delta A \Delta B + \Delta B \Delta A) = \frac{1}{2}[\Delta A, \Delta B] + \frac{1}{2}\{ \Delta A, \Delta B \} ~~~-~(3)
Now, the commutator
[\Delta A,~ \Delta B] = [A - \langle A \rangle I,~B - \langle B \rangle I] = [A,B] ~~~-~(4)
And notice that [A,B] is anti-Hermitian, giving it a purely imaginary expectation value. On the other hand, the anti-commutator \{ \Delta A,~ \Delta B \} is clearly Hermitian, and so, has a real expectation. Thus
\langle \Delta A \Delta B \rangle = \frac{1}{2}\langle [A,B] \rangle + \frac{1}{2} \langle \{ \Delta A,~ \Delta B \} \rangle ~~~-~(5)
Since the terms on the RHS are merely the real and imaginary parts of the expectation on the LHS, we have
| \langle \Delta A \Delta B \rangle |^2 = \frac{1}{4}| \langle [ A,B] \rangle |^2 + \frac{1}{4} | \langle \{ \Delta A,~ \Delta B\} \rangle |^2 \geq \frac{1}{4}| \langle [A,B] \rangle |^2~~~-~(6)
Using the result of (6) in (2) gives :
\langle (\Delta A)^2 \rangle \langle (\Delta B)^2 \rangle \geq \frac{1}{4} |\langle [A,B] \rangle | ^2 ~~~-~(7)
The above equation (7), is the most general form of the Uncertainty Relation for a pair of hermitian operators. So far, it is nothing more than a statement of a particular property of certain specifically constructed hermitian matrices.
Notice that if the operators A, B commute (ie: [A,B] = 0), then the product of the variances vanish, and there is no uncertanity in measuring their observables simultaneously. It is only in the case of non-commuting (or incompatible) operators, that you see the more popular form of the Uncertainty Principle, where the product of the variances does not vanish.
Specifically, in the case where A = \hat{x_i}~,~~B = \hat{p_i}, we use the commutation relation:
[\hat{x_i},\hat{p_i}] = i \hbar ~~~-~(8)
This equation follows from the definition of the quantum mechanical momentum operator, which is constructed upon the following two observations:
(i) In classical mechanics, momentum is the generator of infintesimal translations. The infinitesimal translation operator, \tau (d \mathbf{x}), defined by \tau (d \mathbf{x}) |\mathbf{x} \rangle \equiv |\mathbf{x} + d \mathbf{x} \rangle can be written as
\tau (d \mathbf{x}) = I - i\mathbf{K} \cdot d \mathbf{x}
(ii) K is an operator with dimension length -1, and hence, can be written as \mathbf{K} = \mathbf{p} / [action]. The choice of this universal constant with dimensions of action (energy*time) comes from the de broglie observation k = p/ \hbar. So, writing \tau (d \mathbf{x}) = I - i\mathbf{p} \cdot d \mathbf{x} /\hbar leads to the expected commutation relation , [\hat{x_i}, \hat{p_i} ] = i \hbar.
Plugging this into (7) gives the correct expression for the HUP:
It is this expression that is often popularized in the (somewhat misleading) short-hand: \Delta x \Delta p \geq \hbar/2
* This entry is from our old Library feature. If you know who wrote it, please let us know so we can attribute a writer. Thanks!
Likes Jared Edington
This is an excellent summary of the Uncertainty Principle and how it relates to the properties of non-commuting Hermitian operators. The explanation given is concise yet thorough, and provides a clear insight into the mathematical derivation of the equation. It is also useful to know the origin of the commutation relation between position and momentum, which can be traced back to de Broglie's observation. Great job!
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
