How can I thin lithium grease for use as a lubricant?
  • Thread starter Thread starter dE_logics
    Lithium
When lubricating computer fans, it's important to choose the right type of lubricant. WD40 and similar products dry quickly and are not suitable as long-term lubricants. While lithium grease is effective, its thickness can hinder proper application into bearings. Thinning lithium grease is an option, but caution is advised regarding the use of thinners or WD40 oil, as WD40 is not recommended for lubrication purposes. Alternatives like sewing machine oil or 3-in-1 oil are suggested as suitable options for applying a controlled amount of lubrication.
dE_logics
Hi!
I was about lubricating my computer fan. The WD40/sewing/machine oil dries up quickly so I was wondering about Lithium grease, but unfortunately it's too thick, and it won't flow into the bearings.
So I was wondering about ways to thin it. I read thinner is good, but can I use WD40 oil too? Finally it contains alcohol.
Chemistry news on Phys.org
WD40 should not be used as a lubricant.
Sewing oil, or any of the other oils that come in a can to apply a drop at a time, such as 3 in 1 Oil, should be OK.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
