Calculating Torque for Lever with Weight
  • Thread starter Thread starter choudhari.mayu
    Torque
The discussion focuses on calculating torque for a lever system with weights rotating about a hinge. Users seek assistance with torque calculations for two scenarios: one with a 50 kg weight and another with a 66 kg weight. The initial calculations provided include incorrect unit usage and unnecessary trigonometric functions. Clarifications emphasize the need for standard SI units and consideration of all forces, including the vertical bar's weight. Accurate torque calculations require proper lever length and comprehensive force assessments.
choudhari.mayu
Please find attached image. Help me pleasez find the torque.
Let me know if need any more info. the lever with weight rotates about the hinge. Need torque about the hinge.
1)
Image with 50 kg weight:
the 50 kg weight with link rotates about the red hinge point.
angle is as shown.
please help me out its urgent. need to calculate the torque about the red hinge point.
Assume Distances: black:x red: y conc. Mass size : z x z
2)
Image with 66 kg weight:
Also if we imagine the second position of the lever, it rotating 90 degree about the hinge, the link in black will have zero moment right??
then what will be the remaining torque.
torque= distance * force or load
i calculated the torque as
1) here i did ((30+2+50)*9.81*Sin20degree) * (horizontal distance between red hinge and centre of Blue square mass: 260 mm)
Am i doing it right.?
2)
(4.5*200*9.81) + (66*160*9.81)
Am i doing it right
In (1), length of bar is needed.
sin(20) does not belong anywhere in your formula.
In (2), the units of length are not standard units. Use SI units.
What should be the lever length for the bar? Not 200 mm = 0.2m!
You also left out the weight of the veetical bar holding the 66 kg weight.
