Black Holes: Accretion Disks /Increase/ Angular Momentum?
MattRob
I've been reading Kip Thorne's "Black Holes and Time Warps," and it mentioned something rather counter-intuitive; apparently, when material forms an accretion disk and falls into a spinning black hole, it increases the angular momentum of it.
Now, let's take a gas cloud, and put a spinning black hole in it.
The gas cloud has zero angular momentum as a whole (L_{cloud} = 0), and the black hole itself has L_{hole} angular momentum.
From what I know of classical mechanics, the momentum of the system shouldn't change; once the black hole accretes all the gas of the cloud, it will, according to classical mechanics, spin slower, and the total momentum of the system will stay the same.
∑L_{final} = L_{cloud} + L_{hole} = L_{hole} = ∑L_{initial}
by classical mechanics.
So, am I understanding this correctly, that that classical mechanics' description of the system doesn't agree with General Relativity, and that a full GR description of the same spinning black hole and gas cloud will end with the entire system having more angular momentum?
∑L_{final} > L_{hole initial} + L_{cloud initial} = L_{hole initial} = ∑L_{initial}
by General Relativity.
If that's so, then how? The book didn't go into detail much on how that's the case, but I find it really odd/interesting and would like some insight on how it happens.
No. The full GR description will make calculating the angular momentum much more problematical, though it can be defined in asymptotically flat space-times. But once you get over the hurdle of actually defining the angular momentum, it should be conserved. In some situations, such as inpiraling binaries, gravitational waves (GW) can carry away angular momentum, so you might have to add the GW angular momentum into the total to get a conserved number.
Okay, I'm re-reading this bit again, I think my original bafflement confused me from understanding it properly...
For context, this portion of the book is on quasars and their discovery.
To quote;
How strong will the swirl of space be near the gigantic [black] hole? In other words, how fast will gigantic holes spin? James Bardeen deduced the answer: He showed mathematically that gas accreting into the hole from its disk should gradually make the hole spin faster and faster. By the time the hole has swallowed enough inspiraling gas to double its mass, the hole should be spinning at nearly its maximum possible rate - the rate beyond which centrifugal forces prevent any further speedup (Chapter 7). Thus, gigantic holes should typically have near-maximal spins.
-Black Holes and Time Warps by Kip Thorne
I guess my question then is simply how? There must be a lot of interesting interactions going on in the accretion disk in terms of GWs, then?
I haven't seen any detailed calculations, but my understanding is that there is some residual angular momentum in the interstellar media, it's not zero due to tiny imbalances. This is similar to the solar system, the sun and the planets all have nonzero spins, though the condensed gravitationally from the interstellar media. This process was rather similar in its major outline to the black hole case, t's just in the black hole case, the collapse radius is smaller, so the spin is faster.
The paper by Bardeen might have more info. I'm afraid I don't know much more possibly someone else can help.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
