Word Problem: Increasing Solution Strength to 30%
  • Thread starter Thread starter Diced Tofu
    Word problem
To achieve a final strength of 30% in a 90 L tank currently holding a 20% solution, 15 L of the solution should be drained and replaced with an 80% solution. The remaining solution after draining will be 90 - X liters of 20% solution, which contains 0.2(90 - X) L of the chemical. The added 80% solution contributes 0.8X L of the chemical. By setting the total chemical content equal to that of a 30% solution, the calculation shows that 15 L must be replaced. This process effectively increases the overall strength to the desired concentration.
Diced Tofu
1. A tank holds 90 L of chemical solution. Currently the solution has a strength of 20%. How much of this should be drained and replaced with an 80% solution to have a final strength of 30%?
Mathematics news on Phys.org
Suppose you "drain and replace" X liters of the 20% solution. That leaves 90- X liters of 20% solution. The X liters of the 80% solution will contain 0.8X L of the chemical. The remaining 90-X liters will contain 0.2(90- X) L of the chemical so you will now have 0.8X+ 0.2(90-X) L of the chemical in the final result. How much chemical will there be in 90 L of 30% solution? Set those equal and solve for X.
Answer is 15 L.
thx :D
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
