Speed Of Light and stimilation
Spin_Network
On a par with Einsteins "riding-along-on-a-lightbeam", if I was traveling at the front of a beam of light, and I shone a Laser in the direction of travel, will the Laserbeam work?
Do Laser's travel well?
:confused: :confused: :confused:
i think :rolleyes: it would work perfectly well :approve: and if u could measure the speed of laser beam it would be traveling at c of course. :biggrin:
gurkha
gurkhawarhorse's point is that if you were "traveling at the front of a beam of light" and sent a beam of light from a laser (or flashlight for that matter), you would see it moving ahead of you at c, because, in your frame of reference you are stationary.
Someone in another frame of reference, however, would see you moving at the speed of light and see no light shining in front of you- he would see the light from your laser moving at the same speed as you and so not "shining in front of you".
I, personally, would feel a lot better about that if you were moving at 99.9% the speed of light, relative to the observer. In that case, again, you would see the light from your laser moving away from you with speed c. The observer, as you go flying by, would also see that light moving away from him at speed c, because everyone, in any frame of reference, sees light moving at speed c.
Specifically, if you have speed v (0.999c here but could be anything less than c) and you send a beam of light ahead of you, the observer, relative to whom you are moving at speed c would see the beam of light as having speed
\frac{v+c}{1+\frac{vc}{c^2}}=\frac{v+c}{1+\frac{v}{c}}=
c\frac{v+c}{v+c}= c.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
