Solving the Physics Problem: Position of Object Leaving Compressed Spring
  • Thread starter Thread starter DH
    Challenge
The discussion focuses on determining the position at which an object leaves a compressed spring on an inclined air track at a 30-degree angle. It highlights the dynamics of the object as it accelerates after the spring is released, emphasizing the transition from potential energy to kinetic energy. The key point is that the object will continue to move forward until its velocity surpasses that of the spring as it begins to regain potential energy. The problem requires calculating the exact moment and position of separation based on the spring constant, mass of the object, and the incline. The analysis suggests that understanding the forces and energy transformations involved is crucial for solving the problem.
DH
An object is place against a compressed spring at the bottom of an air track that slope upward at an angle 30. When the spring is release, find at which position, the object leave the spring?
Given: the spring is compressed A, the spring constant is k, m is mass of object, mass of spring is negligible
What have you done so far?
The problem is that, after the object releases from the spring, it will accelerate.. if the velocity of object is greater than spring, the object will leave. but when?
Initially the ball accelerates with the spring as it loses its potential energy , till the point , the spring passes its mean position and starts gaining the potential energy, but the ball remains in motion it had gained . Work on it.
BJ
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
