Comp Sci Converting Temperature Units with C++
The discussion focuses on challenges faced while writing a C++ program for converting temperature units (Celsius, Fahrenheit, Kelvin). The original code has several issues, including incorrect function parameters and a lack of return values, leading to compiler errors. Suggestions include using pass-by-reference for the conversion function and clarifying user input expectations for temperature scales. Additionally, there are recommendations to utilize enumerated types and switch statements for a more logical program structure. Overall, the thread emphasizes the importance of proper function definitions and user interface clarity in programming.
frogdogbb
I know I am not a moron but this C++ is killing me, I have to write a program using functions to convert temp between c, f, k I am hung up
// Mod4project2tempconvert.cpp : Defines the entry point for the console application.
#include <iostream>
using namespace std;
double ftemp (double F, double C, double K, double temp, double scale)
while (scale != 0)
if (scale==C);
F=temp*9/5+32;
K=temp+273.15;
if (scale==F);
C=(temp-32)*5/9;
K=(temp-32)*5/9+273.15;
if (scale==K);
F=(temp-273.15)*9/5+32;
C=temp-273.15;
int main()
double F, C, K, temp, scale;
cout<<"Enter the scale you want to convert from C, F, or K- 0 to quit: ";
cin >> scale;
cout<<"\nEnter temperature";
cin >> temp;
cout<<"\nCongratulations you entered "
<<scale<<"The following results are your converted temperatures "
<<ftemp(C, F, K)<<endl;
return 0;
Any help?
Thanks
#include <iostream>
while (scale != 0)
if (scale==C)
F=temp*9/5+32;
K=temp+273.15;
if (scale==F)
C=(temp-32)*5/9;
if (scale==K)
C=temp-273.15;
int main()
cin >> scale;
cin >> temp;
<<ftemp(F, C, K)<<endl;
return 0;
I only get one complier error:ftemp does not require 3 arguments
Code:
Mark J. Merritt
Temperature Conversion Calculator
Wednesday, April 11, 2001
#include <iostream.h>
#include <math.h>
#include <iomanip.h>
#include <conio.h>
int main()
int choice;
float celsius, fahrenheit, kelvin, temp;
char response;
do
// Clear screen
clrscr();
// Get temperature
cout << "This is a temperature converter." << endl << endl
<< "Enter a temperature to convert: ";
cin >> temp;
// Display choices on which temperatures to convert
cout << endl << endl << "1. Celsius to Fahrenheit" << endl
<< "2. Celsius to Kelvin" << endl << "3. Fahrenheit to Celsius"
<< endl << "4. Fahrenheit to Kelvin" << endl << "5. Kelvin to Celsius"
<< endl << "6. Kelvin to Fahrenheit" << endl;
// Get temperature conversion choice
cout << endl << "Please select a choice from above: ";
cin >> choice;
cout << endl << endl;
// Calculate values based on the choice selected
for the formaulas, please see
[URL]http://library.thinkquest.org/20991/gather/formula/data/129.html[/URL]
switch (choice)
case 1:
fahrenheit=(9.0/5.0)*temp+32;
cout << temp << " degrees Celsius is equal to " << fahrenheit
<< " degrees Fahrenheit.";
break;
case 2:
kelvin=temp+273.16;
cout << temp << " degrees Celsius is equal to " << kelvin
<< " degrees Kelvin.";
break;
case 3:
celsius=(5.0/9.0)*(temp-32);
cout << temp << " degrees Fahrenheit is equal to " << celsius
<< " degrees Celsius.";
break;
case 4:
kelvin=((5.0/9.0)*(temp-32)+273.16);
cout << temp << " degrees Fahrenheit is equal to " << kelvin
break;
case 5:
celsius=273.16-temp;
cout << temp << " degrees Kelvin is equal to " << celsius
case 6:
fahrenheit=((temp-273.16)*(9.0/5.0))+32;
cout << temp << " degrees Kelvin is equal to " << fahrenheit
break;
default:
cout << "That was not a valid choice.";
break;
// Ask to loop back or end program
<< "Would you like to convert another temperature (Y/N)? ";
cin >> response;
// Program loops back if user chooses yes
while (response=='y' || response=='Y');
// Program ends if any other choice other than yes is entered
cout << endl << endl << "This program has been terminated.";
return 0;
The above is an example program. Hope it helps. I wrote one similar to this when I was learning, but it is in C.
What help do you want? What reason do you have to think that this is not perfectly good? You seem to have difficulty explaining what you want- even in the program you have 'cout<<"Enter the scale you want to convert from C, F, or K- 0 to quit: ";'
If I were running the program and saw that message I would be think that I am supposed to enter the letters "C", "F", or "K"- which would then get me an error message because the program is expecting numerical input. What numerical input should I give if I want to convert from Centigrade?
Also, I notice that, although you declare ftemp to return a "double" type, it doesn't actually return anything! You seem to think that the variables, C, K, F will change- they won't, you are calling by "value" here. The function gets copies of whatever numbers are in C, K, and F and works with them- the actual values in C, K, F don't change.
What you need to do is call by "reference". Decalare
null ftemp (double &F, double &C, double &K, double temp, double scale)
so that the values are pointers to the values in memory. The "&" here tells the function that it will be getting pointer rather than the actual values but you can, in the function itself treat F, C, K as if they were the actual values, rather than having to use *F, *C, *K to access the values from the pointers.
In the main program you will need ftemp(&F, &C, &k, temp, scale).
The operator "&" gives a pointer to each variable rather than the variable itself.
I'm still not sure what you want for "scale".
Code:
Dont you have to put a semicolon (;) at the end of your statement?
I didn't notice this until after my remarks about "passing by value" and "passing by reference" (which still stand):
Well, yes, you would! You defined your function by
which takes 5 parameters, and your call is
ftemp(F, C, K) which has only three. What happened to "temp" and "scale"?
I don't know whether you still need help, but you should look into enumerated types and switch statements. Your program can be written in a far more logical manner using these two language features.
