Alignment of Quasar Polarizations 0507274
  • Thread starter Thread starter CarlB
    alignment Quasar
The study confirms that quasar polarization vectors are significantly aligned over vast regions of the sky, with a probability exceeding 99.9%. This alignment occurs at both low and high redshifts, displaying a regular alternation of randomly oriented and aligned vectors with a typical scale of 1.5 Gpc. The mean polarization angle rotates with redshift, showing a distinct mirror-like symmetry between the Northern and Southern Galactic hemispheres. These findings challenge local explanations, suggesting potential global phenomena like photon-pseudoscalar oscillation in magnetic fields. Overall, the alignment of quasar polarization vectors offers a promising avenue for exploring the universe and its dark components on a grand scale.
CarlB
Mapping extreme-scale alignments of quasar polarization vectors
Accepted by Astronomy & Astrophysics; 19 pages, 17 figures. Include Table A1 which will be available via CDS
D. Hutsemekers, R. Cabanac, H. Lamy, D. Sluse
Based on a new sample of 355 quasars with significant optical polarization and using complementary statistical methods, we confirm that quasar polarization vectors are not randomly oriented over the sky with a probability often in excess of 99.9%. The polarization vectors appear coherently oriented or aligned over huge (~ 1 Gpc) regions of the sky located at both low (z ~ 0.5) and high (z ~ 1.5) redshifts and characterized by different preferred directions of the quasar polarization. In fact, there seems to exist a regular alternance along the line of sight of regions of randomly and aligned polarization vectors with a typical comoving length scale of 1.5 Gpc. Furthermore, the mean polarization angle \bar{\theta} appears to rotate with redshift at the rate of ~ 30\degr per Gpc. The symmetry of the the \bar{\theta} -z relation is mirror-like, the mean polarization angle rotating clockwise with increasing redshift in North Galactic hemisphere and counter-clockwise in the South Galactic one. These characteristics make the alignment effect difficult to explain in terms of local mechanisms, namely a contamination by interstellar polarization in our Galaxy. While interpretations like a global rotation of the Universe can potentially explain the effect, the properties we observe qualitatively correspond to the dichroism and birefringence predicted by photon-pseudoscalar oscillation within a magnetic field. Interestingly, the alignment effect seems to be prominent along an axis not far from preferred directions tentatively identified in the CMB maps. Although many questions and more particularly the interpretation of the effect remain open, alignments of quasar polarization vectors appear as a promising new way to probe the Universe and its dark components at extremely large scales.
http://arxiv.org/abs/astro-ph/0507274
Interesting. Any comments? It appears to have initially been rejected by Arxiv, then accepted 60 days later. A theoretical paper referenced is here:
The Dynamical Mixing of Light and Pseudoscalar Fields
Sudeep Das, Pankaj Jain, John P. Ralston, Rajib Saha
We solve the general problem of mixing of electromagnetic and scalar or pseudoscalar fields coupled by axion-type interactions {\cal L}_{int} =g_{\phi} \phi \epsilon_{\mu \nu \a \b}F^{\mu \nu}F^{\a \b}. The problem depends on several dimensionful scales, including the magnitude and direction of background magnetic field, the pseudoscalar mass, plasma frequency, propagation frequency, wave number, and finally the pseudoscalar coupling. We apply the results to the first consistent calculations of the mixing of light propagating in a background magnetic field of varying direction, which shows a great variety of fascinating resonant and polarization effects.
http://arxiv.org/abs/hep-ph/0410006
Carl
Astronomy news on Phys.org
I haven't been thinking about this for years, thanks for the reminder. The paper has seen a lot of citations; looking through the ones that mention anisotropy, it appears that more of the papers find an effect, but I saw one that put limits around zero. If I were going to study it further, I guess I would read this PhD thesis first, as theses tend to have a lot of explanation useful for noobs. He is still active in the field as of last year and still working on polarizations and quasars:
Cosmic anisotropies from quasars: from polarization to structural-axis alignments
Vincent Pelgrims, Doctoral thesis defended December 15, 2015.
https://arxiv.org/abs/1604.05141
As far as speculative explanations, my first guess is a violation of Newtonian physics at extremely low acceleration i.e. MOND. Maybe an explanation for this is that space-time is not isotropic but instead, at sufficiently small distances, has some sort of lattice structure and this breaks Newton's laws when accelerations are on the order of the MOND acceleration. Or maybe an effect could arise from a lattice structure underlying spacetime. Don't see how.
Likes Greg Bernhardt
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
