1-D Projectile Motion: Throwing a Rock
The discussion focuses on solving a physics problem involving the motion of a rock thrown straight up from a bridge. The rock takes 5 seconds to return to the thrower's position, and its final speed before hitting the water, 21 meters below, needs to be calculated. Participants discuss deriving the equation v² - u² = 2as from basic kinematic equations, clarifying the meanings of variables like initial velocity (u) and displacement (s). There is a request for understanding the derivation process rather than just memorizing equations. The conversation emphasizes the importance of grasping the underlying concepts in kinematics.
Jarvis88
[/B]
You throw a small rock straight up from the edge of a highway bridge that crosses a river. The rock passes you on its way down, 5.00 s after it was thrown. What is the speed of the rock just before it reaches the water 21.0 m below the point where the rock left your hand? Ignore air resistance.
[/B]
y= y0+v0t-1/2*gt2
v= v0 -1/2*gt.
I used v= v0 -1/2*gt to arrive at the velocity that the rock was going at the moment it was passing the hand. My answer was v= 0- 1/2*(9.8m/s2), which gave me 24.5m/s. I have an idea of where to go from here. I know I need to use v2 − 2g(y − y 0).
My issue is that I don't want to just memorize the equation. I need help deriving it from the two basic equations: y= y0+v0t-1/2*gt2 and v= v0 -1/2*gt. Once I do that, I believe I can finish the problem on my own.
So, you want to derive?
##v^2 - u^2 = 2as##
##v^2 - u^2 = 2as##
I think so, although I'm not sure what the s and u are for.
##u## is the initial velocity and ##s## is the displacement. I'm not sure why ##s## is used, but it's fairly standard.
Here's my favourite derivation, as it reflects the way I think about kinematic problems:
##v^2-u^2 = (v-u)(v+u)##
Now:
##v-u = at##
Because the difference between the final and initial velocities is just the acceleration multiplied by the time.
And:
##\frac{v+u}{2} = v_{avg} \ \ ## is the average velocity (when you have constant acceleration). Hence:
##v+u = 2v_{avg}##
And
##s = v_{avg}t \ \ ## because the displacement is simply the average velocity multiplied by the time.
So, putting this all together:
##(v-u)(v+u) = at(v+u) = 2atv_{avg} = 2as##
Likes Jarvis88
Jarvis88 said:
[/B]
y= y0+v0t-1/2*gt2
v= v0 -1/2*gt.
You need to check where you got this second equation from.
