Conversion of sound signal to electrical signal
Converting sound signals to electrical signals for practical applications like lighting is highly inefficient due to the low energy density of sound. Most speakers operate at less than 0.5% efficiency, making it impractical to generate significant electrical power from sound alone. Capturing sound energy to power devices like light bulbs would require an enormous amount of sound energy, far beyond typical levels. A more feasible approach is to use a condenser microphone to capture sound and then amplify the signal using an external power source. Exploring alternative project ideas may be advisable to avoid investing time in an unviable concept.
indian_tiger
Hello guys.
I was thinking of making a project in which i convert sound signal to electrical signal which can be put to use for proper electrical work like lighting a light bulb. Can anyone help me on this issue. Like if it is already in practice and feasiblity of such project and how can i go about it.:smile: :smile: :smile:
Very infeasible, sound energy density is very low unless painfully loud. So where do you get the energy source and how do you get close to it because otherwise it propagates in spherical waves and dissapates extremely quickly.
Also, the transducers, the speakers, are incredibly inefficient. A large majority of the speakers are less than .5% efficient. If the conversion from acoustical to mechanical to electrical remained the same in reverse, to light an LED you'd need like enough energy that could light a thousand or even a million LEDs if you captured the energy otherwise (like capture the heat and convert it to steam and then spin a turbine et cetera).
If you simply want to capture the sound to a low-level electrical signal and then amplify it from another electrical power source, you could just take a simple condenser microphone and build/purchase a suitable amplifier that could then drive the light bulb.
I remember my prof talking about how if everyone in New York screamed or yelled as loud as they possibly could and you could somehow contain this energy you would barely be able to light up a lightbulb.
looks like i am on a wrong track. Maybe i have to go for some other topic or try something else in this regard. Guys if you know something else about it please let me know, so that i don't waste much of my time on doing a project which ultimately yields nothing.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
