12 V Battery Conversion to HHO Generator
  • Thread starter Thread starter WhoWee
    Battery Generator
31 replies · 27K views
If weight is not a problem, then your idea should work. and I would suspect that you don't have to change out the acid, if the batteries are placed in a safe location.
I had a battery explode on me when I used one to weld. I was lucky.
but you might have to drill out all of the caps and pull through some oversized flex pvc
with heated ends which will not be able to be pulled through the hole.
such a unit might be ok to weld. however you must use bubble units to stop flash back
to the batteries from the torch and from each battery so you don't lose them all.
Itll explode, don't do it
