Bifilar Coil Formulas: Calculate Capacitance & Impedance
The discussion revolves around the measurement of capacitance in a bifilar pancake coil, with the original poster, Jason, reporting a capacitance of 5.45 uF for a small coil made with 16 gauge wire. Other participants express skepticism about this measurement, suggesting that handheld LCR meters may not accurately measure the parasitic capacitance of coils. They recommend using a full impedance analyzer for more reliable results. Jason plans to verify his measurements at an engineering college and seeks formulas to predict the capacitance based on the coil's specifications. A link to a calculator and relevant equations is provided to assist with these calculations.
Jdo300
Hi Everyone,
I read the Tesla patent about bifilar pancake coils here:
http://www.magnetricity.com/NeoG/Bifilar.php
and I read about how they are supposed to decrease the impedance and increase the capacitance of the coil. So I constructed one to try out the idea. To my surprise, when I tested the capacitance of the coil with my multimeter, it registered 5.45 uF, my coil is only about the size of a CD and made with 16 gauge magnet wire. I attached a picture of it to this post.
I am wondering if anyone out there knows of any formulas to predict the capacitance of the coil given the number of turns (in a flat spiral, not a solenoid), and given the size wire used.
Thanks,
Jason O
5uF sounds way high for a 16AWG coil that size. Are you sure of your measurement? My inexpensive B&K LCR meter gives misleading results unless you're real careful...
Yes I'm quite sure of my measurements. I actually used the new multimeter I recently bought on eBay here:
http://cgi.ebay.com/New-Digital-LCR-Capacitance-Inductance-Meter-Multimeter_W0QQitemZ220001638302QQcategoryZ25421QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
All I did was take some smaller gauge wire and stick it into the holes for Cx and set the dial to measure capacitance in the 20uF range. Then I connected the smaller wires stuck in the meter to the leads on my coil to get the measurement I observed. I also made sure I had the far right button on the meter pressed into measure Cx. I even tested some regular capacitors using the meter just to make sure that I had it setup properly to take the measurements and that seemed to check out fine. However, if you see anything wrong with my measurement method, please let me know and I'll gladly retest it.
Thanks,
Jason O
Nice looking meter! But I do doubt that any handheld LCR meter will be able to tell you the capacitance of a coil like that accurately. The problem is that the meter assumes that you are measuring a capacitor, not measuring the parasitic capacitance of an inductor. You would need to use a full impedance analyzer like an HP 4194. You need to see the full complex impedance versus frequency in order to calculate the inductive and capacitive components (like Lp Cp on the 4194).
My little B&K meter has a D = 1/Q reading that it can make while measuring L or C, and that's helpful to see what the series resistance Rs is. But it doesn't have any way to help me measure the parasitic capacitance of a coil. I go use the 4194 for that.
You should be able to measure the inductance pretty well with the meter. Then you might be able to drive the Lp Cp resonance with a signal generator through a 10kOhm resistor or so, and get the Cp value from that. I'd guess it will be in the 100pF-500pF range or so from the size of your coil.
Hi,
Thanks for the insight. I'll take it over to my engineering college and have them check it out for me to see what the capacitance is since I'm getting questionable results with my meter.
Would you happen to know of any equations I can use to calculate the capacitance of the coils? Maybe I can at least predict what it would be.
Thanks,
Jason O
Here's a calculator that may help. It's the 3rd one down the page. It also gives you the equation, so you can do the calc yourself to check it.
http://www.westbay.ndirect.co.uk/capacita.htm
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
