Understanding Impulse and Conservation of Energy in Bouncing Ball Collisions
The discussion revolves around calculating the impulse experienced by a 5.00kg ball dropped from 1.20m that rebounds to 0.700m. The initial attempts involved calculating the ball's momentum before and after the collision with the floor, but the results were incorrect. Participants suggest using the conservation of energy principle to determine the velocities needed for accurate momentum calculations. The original poster acknowledges confusion over using an incorrect physics equation and expresses intent to retry the calculations using the suggested method. The conversation emphasizes the importance of applying correct physics principles for accurate results in impulse calculations.
xrotaryguy
I don't know why I'm getting the wrong answer on this one.
A 5.00kg ball is dropped from rest from 1.20m above the floor. The ball rebounds .700m. What are the magnitude, and direction of the impulse or the net force applied to the ball during the collision with the floor?
So I started by finding the velocity of the ball just before and just after hitting the floor.
I use that to find the momentum of the ball before and after hitting the floor.
I find the diference between the two momentums and viola! Wrong answer :rolleyes: haha.
The answer is supposed to be 4.28N*s
What am I doing wrong? :cry: :biggrin:
Oops, I found velocity with a physics equation that doesn't exist. :-D However, using the V=sqrt(2ax) formula, I still get the wrong answer...
Yes, you wrote pretty weird things down. :smile:
Use, for example, conservation of energy to get the velocities you need.
Yeah, and I worked so hard at those images too :P
Ok, I'll try conservation of energy.
Thx
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
