Illegal/Dangerous chemical activities
  • Thread starter Thread starter chemisttree
    Chemical
Discussions about illegal or dangerous activities are strictly prohibited on The Physics Forum. This includes explicit instructions on making explosives, drugs, or engaging in hacking. The forum's guidelines specifically address the isolation and purification of chemicals classified as List I under 21 CFR 1310.02, which includes controlled substances and their analogs. Any discussions involving these chemicals are banned, while discussions about List II chemicals may occur but will be closely monitored. List II chemicals, which can be associated with the illegal manufacture of controlled substances, include substances like acetone and toluene. Home experimentation with List I chemicals is considered a dangerous activity and is not allowed, while experimentation with List II chemicals may lead to posts being locked or deleted. The forum emphasizes the need for caution regarding strong oxidizers and highly toxic substances, reinforcing a zero-tolerance policy for discussions that could promote illegal activities.
chemisttree
Illegal/Dangerous Activities:
Explicit "how to" discussions of illegal and/or dangerous activities, or posts advocating such activities, are prohibited; such as: how to make explosives, manufacture crack, steal software, hack into the CIA, ...
The Physics Forum’s guidelines regarding “Illegal/Dangerous Activities” includes
any discussion dealing with the isolation, purification and use of chemicals listed as List I by 21 CFR 1310.02 or controlled substances of any schedule (21 CFR 1308.11-15). Discussions dealing with the isolation, purification and use of uncontrolled chemicals listed as List II by 21 CFR 1310.02 or uncontrolled chemicals which have been associated with the illegal manufacture of controlled substances are allowed but will be closely scrutinized by PF staff. Examples of uncontrolled chemicals that meet these criteria include ammonia, acetone, potassium or sodium permanganate, lithium metal, sodium metal, potassium metal and sodium or potassium hydroxide. A complete list of List I and List II chemicals as defined in 21 CFR 1310.02 can be found at the bottom of this message.
Discussions regarding home experimentation to isolate or purify List I chemicals and those chemicals associated with the manufacture of controlled substances and reactive ingredients in pyrotechnic mixtures is defined as a ‘dangerous activity’ in this Forum and is prohibited. The discussion of home experimentation to isolate and purify List II chemicals will be closely monitored by PF staff and may be locked or deleted for the reasons given above.
List I Chemicals (21 CFR 1310.02)
An-thranilic acid, its esters, and its salts, ben-zyl cyanide, ) ephe-drine, its salts, optical isomers, and salts of optical isomers, erg-onovine and its salts, erg-otamine and its salts, N-acet-ylant-hranilic acid, its esters, and its salts, nor-pseu-doephe-drine, its salts, optical isomers, and salts of optical isomers, phen-ylac-etic acid, its esters, and its salts, phen-ylpro-panol-amine, its salts, optical isomers, and salts of optical isomers, pip-eri-dine and its salts, pseu-doephe-drine, its salts, optical isomers, and salts of optical isomers, 3,4-methyl-enedi-oxyphenyl-2-prop-anone, me-thyla-mine and its salts, eth-yla-mine and its salts, pro-pion-ic anhydride, iso-saf-role, saf-role, pip-ero-nal, N-methyl-ephe-drine, its salts, optical isomers, and salts of optical isomers (N-methyl-ephe-drine), N-methyl-pseu-doephe-drine, its salts, optical isomers, and salts of optical isomers, hyd-riodic acid, benz-alde-hyde, nitroethane, ) gamma-buty-rol-actone (other names include: G-B-L; dihydro-2 (3H)-fur-anone; 1,2-buta-nolide; 1,4-buta-nolide; 4-hydro-xybuta-noic acid lac-tone; gamma-hydro-xyb-utyric acid lac-tone), red pho-spho-rus, white pho-spho-rus (other names: yellow pho-spho-rus), hypo-pho-spho-rous acid and its salts (including ammonium hyp-opho-sph-ite, calcium hyp-opho-sph-ite, iron hyp-opho-sph-ite, potassium hyp-opho-sph-ite, manganese hyp-opho-sph-ite, magnesium hyp-opho-sph-ite, sodium hyp-opho-sph-ite, N-phe-nethyl-4-pip-eri-done (N-P-P), iodine.
List II Chemicals (21 CFR 1310.02)
acetic anhydride, acetone, benzyl chloride, ethyl ether, potassium and sodium permanganate, 2-butanone (or methyl ethyl ketone or MEK), toluene, hydrochloric acid (including anhydrous hydrogen chloride), sulfuric acid, ) methyl isobutyl ketone (MIBK).
Controlled Substances and Analogues (21 CFR 1300-1308 and 21 CFR 1308.11-15)
Chemicals Listed in DEA Bulletins for illegal drugs...
http://www.justice.gov
and then search for "National Drug Threat Assessment"
For Terrorism related chemicals...
http://www.dhs.gov/xlibrary/assets/chemsec_appendixa-chemicalofinterestlist.pdf
Obvious bad substances like strong oxidizers, pyrotechnics and highly toxic and volatile compounds will be watched carefully and home experimentation with same is strictly out of bounds.
Likes Astronuc, berkeman, infactuality and 1 other person
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
