Calculating Average Values and Proving Inequality for Particle Potential - N^nX
ultimateguy
[SOLVED] Virial Theorem
A particle has a potential \lambda X^n and Hamiltonian H = \frac{P^2}{2m} + V(x)
Knowing that the commutator of H and XP is i\hbar(n\lambda X^n - \frac{P^2}{m}), find the average values <T> and <V> and verify that they satisfy:
2&lt;T&gt;=n&lt;V&gt;
The question asked to calculate the commutator and that is what I found, but I'm lost as to how to get the average values and proove the inequality.
The question doesn't actually ask you to calculate the commutator; it gives you the value of the commutator (though with a sign error; it should read ...-P^2/m).
The next step is to recall what the commutator of any operator with the Hamiltonian gives you (Hint: Heisenberg EoM). After that you just have to take the time average on both sides, and take the limit of loooong times.
The question asked to calculate the [H, XP] commutator, I just didn't write it because I already found it and wanted to save time.
I'm not sure I understand the hint.
For an operator A, that is not explicitly time-dependent, (i\hbar) dA/dt is equal to a commutator. Does that help jog your memory?
Thank you! I solved the problem.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
