Saturn Rings: Age and Permanent Feature
  • Thread starter Thread starter pixel01
    Rings Saturn
Saturn's rings may be considered a permanent feature based on observations from the Cassini spacecraft, which analyzed light reflected from the rings and stars behind them. These observations challenge the previous assumption that the rings are young due to their bright, clean ice, which suggested minimal dust accumulation from meteors over time. The Cassini data revealed more material in the rings than previously thought, indicating that the limited amount of meteor dust does not necessarily imply a young age. The article in question appears to have misrepresented these findings, leading to confusion about the rings' age. Overall, the observations support the idea that Saturn's rings could be much older than initially believed.
pixel01
Hi all,
I have read this article about Saturn rings:
http://www.space.com/news/ap-071213-saturn-ringage.html
The author argues as:
Quotes:
"The notion that Saturn's rings may be a permanent feature was based on observations by the ultraviolet spectrograph instrument on Cassini, which viewed the light reflected from the rings and watched stars passing behind them".
In fact I could not understand why for that reasons, they can say the rings are as old.
Thanks for any help.
Astronomy news on Phys.org
It's more that the observations remove the need to assume that they are young!
They were assumed to be young because there are bright clean ice (from IR measurements made form the ground and Hubble) it was thought that if they were old, lots of dust would have built up on them from meteors and so on.
The Cassimi obserations showed that there was a lot more material in the disks than thought so the small quantity of meteor dust present doesn't imply a young age.
Thank you, now I understand.
But it seems the article did not mention what you said. What I read is "..viewed the light reflected from the rings and watched stars passing behind them".
Because they took the real press release and re-wrote it, badly.
http://www.jpl.nasa.gov/news/news.cfm?release=2007-149
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
