#23 intersecting vector equations of 2 lines
  • Context: MHB
  • Thread starter Thread starter karush
    Lines Vector
The discussion revolves around the intersection of two lines represented by vector equations. Participants explore methods to find the intersection point, including converting to slope-intercept form and using parameter values.
  • Technical explanation, Mathematical reasoning, Debate/contested
  • One participant suggests converting the vector equations to the $y=mx+b$ form to solve for the intersection point $(x,y)$ simultaneously.
  • Another participant proposes a specific point $P=\langle 2,3 \rangle$ as the intersection.
  • A later reply questions whether $(\lambda,\tau)$ represents the intersection, indicating uncertainty about the parameters used in the vector equations.
  • One participant clarifies that $\lambda$ and $t$ are parameters for traversing the lines and provides a method to find the intersection point by substituting values into the equations.
  • Another participant presents a system of equations derived from the vector equations and demonstrates the calculation leading to the intersection point $P=(2,3)$.
Participants express differing views on the interpretation of parameters and methods for finding the intersection. While one point of intersection is proposed, the discussion remains unresolved regarding the best approach to derive it.
There are limitations in the clarity of how to handle the vector equations directly, and the dependency on parameter values is not fully resolved.
karush
MHB
the calcs are mine, the only way I could see to solve this was to convert these to the $y=mx+b$ line eq and solve simultaneously to the intersection of $(x,y)$
not sure how you take them as they are given and find point P the intersection just as vectors.
also, I tried to input a vector equation of a line in W|A but my syntax didn't produce the correct line. or is there a an input for that.
Try this, yielding $P=\langle 2,3 \rangle$.
nice to know that
so $(\lambda,\tau)$ is the intersection?
No, it is not. $\lambda$ and $t$ are two parameters that, when you change them, help you to traverse the two lines given by the two vector equations you have. To find the point, plug in $\lambda=-1$ into the first equation, or $t=1$ into the second, and the coordinates you get there will be what you need.
Another approach would be to write the system:
$$5+3\lambda=-2+4t$$
$$1-2\lambda=2+t$$
simplify:
$$4t-3\lambda=7$$
$$t+2\lambda=-1$$
Subtracting 4 times the latter equation from the former, we find:
$$-11\lambda=11\implies\lambda=-1$$
Hence:
$$P=(5+3(-1),1-2(-1))=(2,3)$$
  • · Replies 17 ·
  • · Replies 17 ·
