Efficient and Innovative Offshore Wind Power: The Selsam SuperTurbine
  • Thread starter Thread starter SF
The Selsam SuperTurbine is an innovative offshore wind turbine designed for simplicity and cost-effectiveness, featuring multiple small rotors and a universal joint that allows it to tilt without rotating. This design mimics the flexibility of reeds in the wind and enhances efficiency, as demonstrated by its ability to produce 6,000 watts in 32.5 mph winds. The turbine's structure minimizes the need for slip rings and protects its seals from saltwater exposure. It utilizes a flotation canister for balance and can incorporate a blimp for additional power generation. The turbine is engineered to withstand severe weather and can submerge or lay down during storms, ensuring safety for marine traffic. However, criticisms highlight potential flaws in the concept of constructive interference among rotors and a lack of focus on cost per kilowatt, raising doubts about its practical viability and rotor dynamics.
SF
Is this any good?
The innovative Selsam SuperTurbine off-shore concept was designed for simplicity, as it eliminates all components that do not directly contribute to power generation, resulting in a low-cost wind turbine. The unit is equipped with multiple, synchronous, small rotors and with a universal joint that enables it to tilt. Because of this structure, the turbines resemble reeds bending in the wind. The optional addition of a blimp can make this floating wind turbine even more powerful. The Selsam prototype was able to produce 6,000 watts in 32.5 mph winds, proving the efficiency and effectiveness of the design.
Much like a human back, the unit has a universal joint, attaching it to the generator, which allows it to tilt but not to rotate. The result is that slip rings are no longer required. In order to minimize the amount of salt water splashing the seal, the shroud was extended high above the water line. In addition, the seal can be kept under oil or air pressure for maximum protection.
The company provides the following explanation: "Like a flock of geese, each rotor favorably affects the next in line. Like a set of louvres, the tilted rotors pull in fresh wind from above, deflecting their wakes downward to insure fresh wind for succeeding rotors and, like a stack of kites, to add overall lift which helps support the driveshaft against gravity and downwind thrust forces. The rotors act as gyroscopes or spinning tops, stabilizing the driveshaft where they are attached."
The unit's fulcrum is formed via a flotation canister near the water's surface. Mooring below the surface balances the weight of the small rotors and driveshaft. The driveshaft is responsible for generating electricity once the wind rotates the turbine's blades. It also consists of a buoyant, thickened, hollow base that acts as the main bearings of the turbine. A blimp can be added to the turbine in order to generate additional power.
"Many other mooring methods, including interconnected mooring grids, are appropriate depending on windfarm layout, number and size of turbines, local marine traffic, tides, currents, waves, and depth," the company further explains.
The Selsam SuperTurbine is designed to withstand harsh weather and storms. When necessary, it can lay itself down or submerge completely using its flooding chambers. It also poses no risk to passing vessels, since it is relatively lightweight and mobile.
TFOT recently covered other innovative wind turbines, including the Repower 5M, which is one of the largest and most powerful wind turbines in the world, with a rated power of 5 megawatts, a rotor diameter of 126 meters, and a hub height of around 90 meters at sea and 120 meters on land. In addition, TFOT reported on Blue H Technologies' plans to build a deep water offshore wind turbine by using a new technology, which they have developed based on ideas borrowed from offshore oil and gas platforms.
http://www.tfot.info/pod/1183/selsam-superturbine.html
Computer science news on Phys.org
What appears to be their main point - constructive interference between the turbines - is just flat-out wrong. A flock of geese flies in formation because there is less energy lost to drag (ie, the wind). A turbine is generating from the wind, so the concept is reversed: putting tubines in formation results in less energy being gained from the wind.
Other than that, it doesn't really say anything at all about the fundamental selling point of any wind turbine: cost per kW.
With shafting like that, the rotor dynamics of that thing could be a nightmare. I doubt this thing will ever get built.
I came across a video regarding the use of AI/ML to work through complex datasets to determine complicated protein structures. It is a promising and beneficial use of AI/ML. AlphaFold - The Most Useful Thing AI Has Ever Done https://www.ebi.ac.uk/training/online/courses/alphafold/an-introductory-guide-to-its-strengths-and-limitations/what-is-alphafold/ https://en.wikipedia.org/wiki/AlphaFold https://deepmind.google/about/ Edit/update: The AlphaFold article in Nature John Jumper...
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
