Solving Trig Problem with Square Root: [0,2π) Interval | Forum Help Needed
  • Thread starter Thread starter Geekchick
    Trig
The problem involves solving the equation √3sin(x) - 3cos(x) = 0 within the interval [0, 2π). The initial approach suggests dividing by cos(x) to simplify the equation to √3tan(x) = 3, leading to tan(x) = √3. The solutions for x in the specified interval are found to be π/3 and 4π/3. The discussion also highlights the auxiliary angle method as an alternative approach, confirming that multiple methods yield the same results. Overall, the thread provides guidance on tackling trigonometric equations effectively.
Geekchick
\sqrt{}3sinx-3cosx=0 solve in interval [0,2\pi)
reciprocal identities, pythagorean identities, confunction identities, Even/odd identities, sum/difference formulas, double angle formulas, power reducing formulas, half-angle formulas, sum to product formulas, product to sum formulas. I am not sure how many of those are relevant but that's all the identities and formulas I have learned so far.
To be quite honest I don't even know where to start with this problem : ( mostly the square root of three is throwing me. I have been trying to solve this for days so if anyone could so much as tell me what formulas or identites to use i would appreciate it. I'm just so lost.
Oh also I'm new to this forum, just found it tonight, so i just want to say hi to everyone!
\sqrt{3}sinx-3cosx=0 \Rightarrow \sqrt{3}sinx=3cosx
Can you divide by cosx and go from there?
Thank you! Thank you! thank you! I didn't even think about the fact that sin/cos is equal to tan duh! *smacks head* I was trying to make things way more complicated. So just to be sure once I divide by cos I'm left with the (square root of 3)tan=3 which after dividing that by the (square root of 3) and simplifying I have tan= square root of 3 which in the interval [0,2pi) means my answer is (pi/3) and (4pi/3). Yay!
Gib Z said:
In general, for things like a sin x +/- b cos x, we can combine them into a single sine term, using something known as the Auxiliary Angle method: http://en.wikipedia.org/wiki/Trigonometric_identity#Linear_combinations
EDIT: Damn, too late and a longer method. lol
The "auxiliary angle" method is fine -- it's just "overkill" on the equation
a sin x + b cos x = c
in the case where c = 0. When you follow through with it for this problem, you get
sin(x - \frac{4 \pi}{3}) = 0 \Rightarrow x - \frac{4 \pi}{3} = ..., -\pi, 0, \pi, ...
with the results in the fundamental circle being the two Geekchick has found. (I'm just elaborating on this since it's always good to know multiple methods for solving a problem and to confirm that they all give the same answer.)
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
