A Proton is fired from far away towards the nuclues of a mercury Atom
A proton is fired towards a mercury atom's nucleus, which has a diameter of 14.0 femtometers (fm). The initial kinetic energy of the proton is calculated using its mass and speed, while the potential energy at closest approach is determined using the charges of the proton and the nucleus. The discussion emphasizes the need to convert the charges of the nucleons into Coulombs for accurate calculations. The key relationship established is that the kinetic energy at a distance far from the nucleus equals the potential energy at the closest approach. The final goal is to solve for the separation distance, r, using the equation that equates kinetic and potential energy.
Blitzp22
A proton is fired from far away towards the nucleus of a mercury atom. Mercury is element number 80, and the diameter of the nucleus is 14.0 fm. If the proton is fired at a speed of 32100000 m/s, what is its closest approach to the surface of the nucleus (in fm)? Assume that the nucleus remains at rest.
U=kq1q2/r
kinematic equation
K = 1/2 m v^2
So I got this far
1/2(1.67E-27)(3.21E7)^2=(9E9)(q1)(q2)/7fm
but I don't know what to do about the q1 and q2 to get my final answer. Hmmmm toughy
The q's are the charges on the nucleii. You can look them up on a periodic table. Remember, the charge shown on the table is in terms of electron or proton charges which you must convert into the standard unit of Coulombs. No doubt you have the charge of an electron in one of your lists.
Your calc is right, but difficult for me or your teacher to understand. Maybe you, too. You really should start with a general statement that shows your method of attack. Something like this:
Kinetic energy far out is entirely converted to potential energy at the closest approach
or KE far out = PE @ turnaround
yeah but in response to Delphi51's comments, then what are searching for? you would've filled all the unknowns in the equation
Welcome to PF, richnut.
You would still be looking for the separation distance, which is the r in the original post. It just makes more sense to write:
1/2 m v^2 = kq1q2/r
The first step clarifies what the second means. Then you go on to solve for r.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
