Solving a 2D inelastic collision involving cars and tricycles
In summary, you collide with another car traveling with a relative velocity of 15m/s and have a speed of 4.72 m/s after the collision. You have a change in kinetic energy of 6.12 joules.
Sally99
You are moving due North in your car with velocity (0, 20m/s). You see another car traveling with a relative velocity of 15 m/s with an angle of 150 degrees. You have a mass of 30 kg, the other tricyclist has a mass of 40kg and the tricycles both have mass 10kg. You collide and stick together.
a) What is your velocity right after the collision?
b) Just after the collision, at what angle are you moving with respect to the x-axis?
c) What is your speed after the collision?
d) What is your change in kinetic energy from the collision?
Vac = Vab + Vbc
m1v1 = (m1 + m2) v2
tan-1 = Vy/ Vx
pythagorean theorem
First I would use the relative velocity equation to find the velocity of car 2 with respect to the ground. I'm not sure how to set this up though. Then I would use the x and y components to solve for the angle. After, I would use these two values and plug them into the pythagorean theorem. Finally, I can't seem to figure out what the equation is for change in kinetic energy!
Any help from you guys would be greatly appreciated! I'm really stuck here :(
Ok so i noticed no one is replying to my thread so I'm going to elaborate a little.
to solve for initial velocity of car 2 i wrote
V21 = v2g - v1g
(-7.5, 13.0) = v2g - (0, 20)
v2g = (-7.5, -7)
Then to find the final velocity i did
m1v1 + m2v2 = (m1 + m2) v2
(40)(0,20) + (50)(-7.5,-7) = 90v2
(4.72, -3.89) = v2
theta = tan-1 3.89/ 4.72
= -39 +180
= 140
c) asquared =bsquared = csquared
(4.72)^2 + (-3.89)^2 = c^2
c= 6.12
Then change in KE = ?
There may be an easier approach. Only relative velocities matter in mo conservation. So assume you are rest and collide with the other tricycle. What is your new velocity relative to the assumption of zero V initial velocity. Add this vectorially to the initial velocity by breaking down to x,y components. Compare the 1/2mv^2 values of the cars or tricycles. Same approach basically.
If I solved it using relative velocities would it give an incorrect answer?
Nope, so long as you do what I describe and consider the initial veocity as part of the kinetic energy. In other words if you were on a bike at 50 mph and hit a flea...
Here you are hitting an object of similar mo. But you had KE before and that needs to be considered. If you compute the changes in velocity from your assumption, then add these to the initial velocity of 20m/s and use Pythags to get a resultant velocity, square that and remember that the final mass is the sum of the two,...
Momenta conservation:
MOx=Cos(150)(15m/s)(40Kg)=(40kg+30Kg) Vx;
Vx is relative change in horizontal V, solve for it
MoY=Sin sin(150)(15m/s)*(40Kg)=(40+30)*Vy solve for it and subtract from initial Vy of 20m/s
Calculate the resultant velocity and using 1/2 mv'^2-1/2mv^2, compute the change in KE.
Ahhhh ok I see, thanks so much for your input!
1. What is a 2D inelastic collision?
A 2D inelastic collision is a type of collision that occurs between two objects in a two-dimensional space where both objects stick together after the collision and move with a common velocity.
2. What is the difference between an inelastic and elastic collision?
In an inelastic collision, the kinetic energy is not conserved and is converted into other forms of energy, such as heat or sound. In an elastic collision, the kinetic energy is conserved and the objects bounce off each other with no loss of energy.
3. How is momentum conserved in a 2D inelastic collision?
In a 2D inelastic collision, the total momentum of the system before the collision is equal to the total momentum after the collision. This is known as the law of conservation of momentum.
4. What are some real-life examples of 2D inelastic collisions?
Some examples of 2D inelastic collisions include a car accident where two cars stick together after the collision, a cue ball hitting and sticking to another ball in a game of pool, or a person catching a ball and bringing it to a stop.
5. How do you calculate the final velocity in a 2D inelastic collision?
The final velocity in a 2D inelastic collision can be calculated by using the conservation of momentum equation, which states that the initial momentum of the objects is equal to the final momentum. This equation can be rearranged to solve for the final velocity.
